best 50cc yak
best 50cc yak
hello,
according to you, which is the best yak : EF, QQ, HANGAR9 CARDEN...there is so possibilities, i don't know what to choose in few months, i've got an aera 51 to power it, perhaps with a pipe i would like power but no noise..
thank you
stephane
thank you
stephane
My Feedback: (10)
TX
RE: best 50cc yak
ORIGINAL: mm
hello,
thank you
stephane
hello,
thank you
stephane
I have flown all three of the one you mentioned. The EF is the best. The quality is much better and it flys better. A pipe is nice to have with a 50 but it's fine without it.
RE: best 50cc yak
well, i love the carden but it seems to be less bigger than EF? is it right ? i haven't seen any of them
thanks
thanks
My Feedback: (10)
TX
RE: best 50cc yak
ORIGINAL: mm
thanks
thanks
The Fuse is larger on the EF. The H9/Carden does fly good, but it's hard to get over a Yak that has flat sides on the fuse. The firewall doesn't have the right thrust built in so you have to shim it. The stabs don't have an alignment pin so you have to reset the incedence every time you take the Stabs off.
RE: best 50cc yak
Ohio Model Products is bringing out three new 50cc models to our lineup! Working with EG Aircraft we have downsized our Yak 55SP and the Extra 300 mid-wing from the 100cc sizes to the 50 cc size as well as picking up some new and exciting offerings from EG Aircraft. We expect delivery in mid Nov with shipping to begin immediately after that. Save 50 bucks if you pre-order early!
I'm slowly working on the front page to spice it up with the new giant scale offerings but we've got the pre-order pages up for the three new 50cc offerings. And they can be found through any of the pull-down menus on the pages. Here are the link for the new 50cc Yak. The pipe tunnel is plenty big enough for the typical canister.
50 cc Yak 55SP:
http://www.ohiomodelplanes.com/50ccyak/index.htm
50 cc Yak 55SP:
RE: best 50cc yak
well,
i think my choice will be between carden yak and EF yak ? which will be better ? i know it is hard to choose...
thanks
stephane
thanks
stephane
My Feedback: (10)
TX
RE: best 50cc yak
One of my freinds here bought one of the Carden Yaks when they first came out. He kept it maybe 2 months before he sold it and bought an EF.
If you could look close at both it would be an easy decision.
IL
RE: best 50cc yak
too bad the EF yak, 87" lenght wont fit in my truck , so I got the next best thing, the aeroworks yak, with a 55DLE. I think that should be enough for extreme 3D
RE: best 50cc yak
well,
i have a new area51 which seems perfect, all my servos and my receiver, but about plane, i should buy an EF or carden yak, always impossible to choose, it isn't for now but those two airplanes seem incredible..
Stephane
Stephane
