Noise and interference
Hi every body
i have a 36% the world models katana 100 cc. When the assembly of the plane was finished , I have lots of noise and interference in all of the servos. 1× rg7318 receiver 1× dualsky duo pro regulator 2× multiplex Digi 5 Titan on elevators 4× savvox 0220 servo on ailerons. So anybody can help me how I can spoil the noise on my system. lots of thanks |
You can eliminate 1 servo at a time and see if it ever clears up. I would suggest a lower voltage battery to eliminate the regulator as I suspect it as most likely guilty.
Originally Posted by TexasFlash
(Post 12549242)
But You say the regulator is base of the noise? |
Make sure the plug caps are FULLY seated. If you don't have a near permanent mark on you hand from pushing the plug cap on its probably not fully seated.
That, more than anything else, is the source of noise in a 2.4 system on a gas plane |
Originally Posted by BarracudaHockey
(Post 12549254)
That, more than anything else, is the source of noise in a 2.4 system on a gas plane I check it and say you what I see. 👍🙏 |
Originally Posted by am_egh
(Post 12549247)
thanks dear friend for your reply
(Post 12549286)
Nope! I said to eliminate each item one at a time to test. But if this only happens with the engine running focus on plug wires as stated above first. I read your question as if the noise is always there and not just when the engine is running. While regulators aren't common for problems, a poorly designed one can do this. Lots of thanks I test it |
Problem was fixed
HiFirst I fastened all the plugs onto the receiver
And then I kept the regulator as far away from the receiver as possible. The problem was fixed and I did several tests at different times Thanks to all the friends for the tips Good luck |
