RCU Forums
-   Giant Scale Aircraft - 3D & Aerobatic (https://www.rcuniverse.com/forum/giant-scale-aircraft-3d-aerobatic-110/)
-   -   Split elevator setup (https://www.rcuniverse.com/forum/giant-scale-aircraft-3d-aerobatic-110/1598929-split-elevator-setup.html)
Xrod 03-07-2004 08:22 AM
Hi guys,
I just bought a GP Giles 202 1.20 size that has split elevators utilizing two servos. I have a Futaba 6EXA transmitter that doesn't have the advanced mixing features that I think people use to operate this setup. Whats my best option? Y cable with one reversed? This is my first "large" plane. I've read the thread on the fuselage reinforcement. Thanks
MR G 03-07-2004 08:46 AM
RE: Split elevator setup
I would use the two servos on a Y cable and set the servo arms in opposite directions. Make sure that the angle of the servo arms to the pushrods are the same, the fact that one points up and the other points down is far less important than the pushrod servo arm angle.
Good luck, keep it flying!!
MR G
Hammbone 03-07-2004 09:29 AM
There are several ways to do this without a better TX, but none of them are satisfactory IMHO.
If you are getting into planes that require this type of set-up now, why don't you just "bite the bullet" and upgrade your TX? Keep your current one as a back-up or trainer TX, or sell it.
I just think you will be much better off with a TX that is up to the task, rather than trying unsatisfactory fixes.
While you are at it, buy a TX that will last you a long time so you won't ever need to upgrade again in the future. If you plan on getting into 35% or 40% planes eventually, buy the top of the line TX and it will serve you well for a long time.
Jim
FBaity 03-07-2004 10:37 AM
I have a Sig Cap 231 set up on a magic Y ( reversing device ) and it works great and is simple.
DGrant 03-07-2004 10:55 AM
HorizonHobby.com carries a servo-reversing Y-harness. I don't recall the part number, so you'll have to search for it on the site. It works fine for what your needing, and cost is actually no more then standard Y's(I'm thinking about $10-$12). It even has a finite adjustment pot for fine tuning. I've used a few of these with excellent results. I do think though as Hammbone said, a new transmitter might well be in your future. There's alot of brands of transmitters that will offer that mix within programming. I have the Futaba9C and it does offer that feature, although I have used it both ways for the set-up your talking about. Really either way works just as well. Good luck, you'll do fine. :)
Tired Old Man 03-07-2004 11:10 AM
There are 3 excellent ways of setting up your split elevator without buying a new transmiter. Both JR and Futaba make a product for plugging up to 4 servos on one channel. JRs' is called the Matchbox. I don't know the name of the Futaba product. JRs' sells for around $70.00 each or 115 per pair. Both will let you reverse one or more servos from the matching unit. Both will let you PRECISELY match the center and end point positions of the servo. A very desirable condition. Both are small and light.
If you are using Hitec digital servos, you can purchase one of Hitecs' digital servo programmers and set both servos to the condition you wish them to be. You can also match the servo speed, center, and end points for perfect control harmony.
Those suggesting using a "Y" harness with a reversing function are setting you up for a lot of problems. It's also very old school thinking. Some of them are changes of control position as the reversing switch gets warmer. Inaccurate servo adjustment through the reversing pot, poor servo centering, and differences in servo speeds. All cause problems. Using the newer products using current technology will save you a lot of time and grief. It may cost you a little, but it may also save you more than you want to lose.
Geistware 03-07-2004 11:13 AM
The most economical method is to use a reversing Y harness.
I have seen many who have used this successfully.
I also heard of two crashes where the failure was due to electonics failure in the servo extension. One was a reversing Y and the other is an amplifier.
Hammbone 03-07-2004 11:52 AM
ORIGINAL: Silversurfer
I agree with this post. I said that there were no satisfactory ways of doing the slipt elevator thing without the upgraded TX, but I forgot about the matchbox and the programmable Hitec's. Either of these would be a good solution. They both involve spending some money though, so you can do one of these two things, or you can put that money towards a new TX.
When using the reversing "Y"s or reversed servos (non-programmable), etc. There always seems to be some problems. Either you can't get the elevator throws to match up or the speed of each elevator is different or something.
Jim
DENNIS C 03-07-2004 11:55 AM
I have used the y-harness with the adjustment pot in it. it worked good. you just have to keep a eye on it. cause with tempeature changes it throw the adjustment off
CK1 03-07-2004 07:26 PM
I have used various reversing "Y's" over the years and have not been totaly satisfied with any of them. Some are temperature sensitive , some are voltage sensitve and some just do not maintain centering . On some planes small variances are almost unoticed in flight, on larger aerobats
(27% and up) those small variances are extremely noticible .
The best solutuion i've found is the JR matchbox , no floating contols , centerpoint and endpoint adjustible (needed - if your not a very precise on your linkage geometry)
So if your happy with your current TX and arent up to purchasing the newest in Techno-Wonder Transmitters go with a Matchbox or the Futaba
Equivelent .
I'm not trying to push JR products , in fact I'm a die hard Futaba man . I've been using the matchbox since they came out , and Futaba didnt have an equivelent at the time , they work so good I haven't tried the Futaba version .
Xrod 03-07-2004 07:41 PM
Thanks for all the great info. Yes I do want to get a new transmitter, I have been looking at a Futaba 9CAP, but it will be a while. I just got done buying plane and engine! I would rather put the money into the new receiver than to spend a quarter of that on a matchbox setup. I think I will try the Y cable with trim pot for the time being. Can anyone tell me where to order that? or a part number? Thanks for your help.
Steve
DGrant 03-07-2004 08:25 PM
http://horizon.hobbyshopnow.com/prod...p?prod=EXRA325
This is it..........a whole $8.95 It's the heavy duty...same as I have in my Edge540 w/Moki 1.80. Go for it! :D
JCOKEEFE 03-08-2004 10:44 AM
Are the connectors compatible with Hitec servos and receivers?
I looked at the referenced Horizon Hobby site shown on your thread,
and when ordering this connector, there is no option to
specify connector type.
tommy s 03-08-2004 10:56 AM
Another option that seems to be overlooked here is to use only one servo
which should be more than adequate on a 1.20 size airplane. The new digitals
with over 250 in. ozs. of torque will handle any control surface on this size airplane.
tommy s
falcon6171 03-30-2004 03:30 PM
can the hitec eclipes radio do the mixing for a split elevator (two servos on elevator) ? ive never tried it i just use a y cable
JCOKEEFE 03-30-2004 04:03 PM
I tried mixing split elevators (one servo per elevator) with my Eclipse and
mixing with one elevator half on channel 2 and the other elevator
half plugged into channel 6. It works fine with one exception, if you want to trim
your elevators, only the elevator plugged into channel 2 will trim. The
channel 6 (slave) elevator remains stationary. I opted to use the
y cable with servo reversor.
Edwin 03-30-2004 04:47 PM
Another option that I recently did was to use a torque rod setup. I used 5/32" music wire (why do they call it that) with flats filed and 3 nose gear arms. The servo goes to one of the arms and the other 2 arms go to the elevator halves. I found this easier to setup than duel servos.
Edwin
Saberjock 03-30-2004 04:56 PM
So far I haven't read the option of buying a JR servo of the same power and speed as your Futaba. It rotates in the opposite direction making the tail mounted elevator servos act in unison with a simple "Y" cord. Tex.
Geistware 03-30-2004 07:45 PM
YOu can do this with a Hitec and Futaba as well
ORIGINAL: Saberjock
smokingcrater 03-31-2004 12:15 AM
won't they probably have different travel ranges? (yeah, probably different speeds also, but that isn't usually much of a problem...)
Geistware 03-31-2004 06:33 AM
You can find servos with speeds that are close enough. YOu can use you adjust your endpoints to make them travel the same. I have only done it once before then purchased an 8U and the problem went away.
ORIGINAL: rkramer
pettit 03-31-2004 07:31 AM
Ask around in your area if there is someone that has the technical ability to electrically reverse the servo inside it's case.
It's a relatively simple matter of reversing the wires on the motor and the ones on the outer edge of the pot, but it can be done.
Even the new ones with the motor soldered directly to the PC board can be reversed.
I do it all the time.
Just make sure you mark the case with a big "R"...
DGrant 04-02-2004 02:58 PM
Wow.....I've used the reversing Y in 3 planes already. No trouble at all. If Xrod doesn't have the $$ to buy a new Tx...why would Xrod want to spend the $$ on a Matchbox, reversed servo, or another high dollar 250oz. servo/linkage??
Yes the reversing Y will work with the Hitec connectors, no sweat. Common sense tells me, there's as much of a chance of problem with ANY electronic component. The Y has just as much chance of a prob as the Matchbox set-up. I've seen alot of culprit components, and you really can't say what will go wrong. Go for the Y....it's simple, reasonable price, and it will get you in the air. Now go fly!!! :D
falcon6171 04-02-2004 08:25 PM
i just use a "y" cable with no reverse with two of the same servos i havent had a problem yet i just have the arms the same on both i put the rudder servo in between them facing the opposite direction to give me space for the arm
NJ Georgee 04-14-2004 11:44 AM
I have a question simular to the tread topic,Im building my first plane and I joined the elevators to function together.Will this plane be able to come out of a angle and fly streight.I was thinking of making the wing flaps functional for this porpose. would I be better off seperating the elevators and leave the wing flaps non functioning.All I want is the plane to fly normally no acrobatics ,
