RCU Forums
-   Giant Scale Aircraft - 3D & Aerobatic (https://www.rcuniverse.com/forum/giant-scale-aircraft-3d-aerobatic-110/)
-   -   Rudder pull-pull question?? (https://www.rcuniverse.com/forum/giant-scale-aircraft-3d-aerobatic-110/1925283-rudder-pull-pull-question.html)
Bass1 06-22-2004 12:35 PM
Hi, I am concerned about using the recommended Du Bro pull pull system for my 27% Cap with a Gas engine. Should I be concerned with the"nylon coated stranded steel cable"? Will this be a source of interference? I am aware that Don's Hobby Shop carries a coated kevlar setup but would prefer something I can get locally. Thanks in advance
JoeAirPort 06-22-2004 12:50 PM
RE: Rudder pull-pull question??
ORIGINAL: Bass1
Keep your antenna as far away as possible and you should have no problems. It's only when people run antennas close to the pull pull cables that it reduces the range of your rx. Also keep your antenna away from any servo extension cables. You could for example run your antenna all the way in the top corner of the inside fuse. Run your servo extensions on the other corner. The pull pull will run close to the center of the fuse. This is plenty of separation.
Bass1 06-22-2004 01:43 PM
Thanks Joe Airport. That's what I do with my glow airplanes. I was just looking for a second oppinion.
Stick Jammer 06-22-2004 07:57 PM
The cables are usually isolated at each end with a nylon ball link so RF is normally not a problem. I will also add that if the cables cross be sure they are separated so they don't rub together.
geneh-RCU 06-22-2004 11:22 PM
On my 27% cap its not a problem. Ill send you some pictures tomorrow so you can see the pull pull setup. The cables are thin enough that I dont think you will have a problem.....
Matt
What goes up must always come down, but what comes down may not always go back up!
