RCU Forums
-   Giant Scale Aircraft - 3D & Aerobatic (https://www.rcuniverse.com/forum/giant-scale-aircraft-3d-aerobatic-110/)
-   -   What size of engine? (https://www.rcuniverse.com/forum/giant-scale-aircraft-3d-aerobatic-110/311128-what-size-engine.html)
RussellE 10-11-2002 05:31 PM
I have come across an airplane not knowing what size engine to put in it. It is called a "Soft Touch" 90 inch wing, 1425 in wing area, high wing. It is a very strong stuture. The plane weights 12.5 lbs empty. I have seen these engines for sale, used, relatively inexpensive. Am I even close to the right size engine?
MDS 2.18
magnum 1.8
Supertiger 2350
Any input is better than what I know about the big birds.
IXLR8 10-11-2002 08:20 PM
engine size
You are probably pretty close. Of course it depends how much wing area you have and how you plan to fly it. You could probably even use a 120 although it might not have as much power as you would like. If you aren't too concerned with performance and want to go cheap(relatively speaking) you might consider getting a reasonably priced gas engine such as a Ryobi 31, US 35,41 etc. Then you will save even more on fuel.
