RCU Forums
-   Giant Scale Aircraft - 3D & Aerobatic (https://www.rcuniverse.com/forum/giant-scale-aircraft-3d-aerobatic-110/)
-   -   Pull Pull Cable Crimps (https://www.rcuniverse.com/forum/giant-scale-aircraft-3d-aerobatic-110/3259736-pull-pull-cable-crimps.html)
PTS 08-13-2005 05:23 PM
What is a effective method of crimping pull pull cables without overstressing or damaging the cable? Is there a special tool? Please any advice...
Perry
scottfl78 08-13-2005 06:02 PM
RE: Pull Pull Cable Crimps
1 Attachment(s)
I loop mine once and crimp them twice with the needle nose pliers.. If your cable is teflon coated(or similar) the cables wont be harmed.. Here is a pic of my edge though my loop could have been smaller.. I know there are specialized pliers for crimping similar to what we use for fishing rigs but I don't have any..
blikseme300 08-13-2005 07:04 PM
Perry
You can get a crimper from most Walmart stores in the fishing section.
Safe Flying!
FlyingPilgrim 08-13-2005 07:27 PM
I use an electrical terminal crimping tool. I've seen them for sale everywhere, either have yellow or orange grips, wire strippers built in. It has radiused/curved recesses to crimp terminal ends onto wires.
mglavin 08-13-2005 07:29 PM
As mentioned loop through one time and back again and crimp. I use crimpers for non-insulated electircal connectors. The fishing tackle guys use essentially the same thing. Home Depot, Lowes and others have crimper-wire stripper combination tools.
rmh 08-13-2005 10:39 PM
Some cables will only pass thru the supplied ferrules twice- thru and back
not to worry - use ONLY nylon coated cables - Berkeley Steelon Leader is easily the most popular -
I crimp using Vice Grip pliers
you can imprint the cable thru a copper or thin steel ferrule.
Never had these slip -even using 2, 8611A servos
(80 lb test leader)
bodywerks 08-14-2005 02:30 PM
I am looped through only once like Dick suggest. I just lightly sand the snds of the cable with 400 before crimping, and I crimp in such a way as to spread the cables away from each other and I crimp top and bottom. Then, I wick some thin CA in just for good measure...no problems yet.
DENNIS C 08-16-2005 02:31 PM
Im able to pass the wire thur the ferrit 3 times then crimp with vise-grips.
I Really dont see what C/A is going to do for this:eek:
tbrock21 11-14-2024 09:43 AM
CA will absolutely help the wire stay in the crimp. Anyone who has ever taken a pull-pull cable apart to change it out knows this because you cant hardly get that CA OFF OF THE CABLES NO MATTER HOW HARD YOU TRY...... It absolutely helps!!!!
