RCU Forums
-   Giant Scale Aircraft - 3D & Aerobatic (https://www.rcuniverse.com/forum/giant-scale-aircraft-3d-aerobatic-110/)
-   -   1/4 Scale J3 CUB which is best??? (https://www.rcuniverse.com/forum/giant-scale-aircraft-3d-aerobatic-110/3692587-1-4-scale-j3-cub-best.html)
dove57 12-26-2005 09:04 AM
Hi, With many designs of the J3 CUB out there,I'd like to know which 1/4 Scale version is the best from
available plans or kits , not the ARF's thanks;)
dove
CUB1 12-26-2005 01:40 PM
RE: 1/4 Scale J3 CUB which is best???
dove,
I like the Sig 1/4 Scale kit, it comes out light and it is a good flier.
I have the clip wing version with a OS 1.60 twin. The plane is about 13 years old.
khodges 12-26-2005 06:16 PM
I'd have to second the above post regarding Sig. Good kit, been around a long time. BUSA also makes a good 1/4 scale Cub, and I like the way the center section and wings are made a little better. The Sig's wing is two piece, but the center section is part of one wing; you put the wing 'halves' together, and then use wing bolts to attach the wing to the fuse.
With the BUSA kit, the center section is part of the fuselage, and each wing half fits on dowels that stick out of the center section at the roots, and the wing halves fit on them, and are held on by screws inside the cabin; it's a cleaner attachment, looks better IMO, and if you want to modify the plane to make it an L-4, it's easier to do. Can't go wrong with either one, though.
T. Bob 12-27-2005 12:08 PM
I know this is against everything I stand for regarding people answering an unasked questions BUT, I saw an article lately on how someone bought a Dave Patrick ARF Cub, they recovered it and did some significant modifications and it looked great. I know you only asked for kits and I'm sorry to add and ARF into this thread but the plane looked great and with the modifications it was very original looking.
bps 12-27-2005 01:04 PM
I have the Sig 1/4 scale in the clipped wing version. It is in the que for this winter sometime. Looks like a nice kit to me, lots of building to do but then that's why I build kits.
JEB:D
Stickbuilder 01-01-2006 06:48 AM
Well, here I go again...The Sig kit is a great flyer, but the Balsa USA kit is more labor intensive, flies better, (given equal power), and has more scale fidelity. (it's not a real bear to build just requires more attention to detail) I've done several of both. I hate to start another one, but I will in all likelyhood do the BUSA kit with another OS 120 (non pump) for power again. I'll use Koverall and dope again. (looks right) (iron on never does) For what it's worth.
BigBird1 01-01-2006 05:10 PM
A BUSA Cub will fly great with a Saito 180...or a G38..(as in hover)..is more labor intensive...BUT well worth the effort..the wing bolts are a PITB..and the eyelets for the cabin braces need to be exchanged from the cad plated copper ones to steel..(they break).
BB1
bps 01-02-2006 08:08 AM
basabandit,
Do you have a reliable sorce for the Koverall? Sig is out of stock and keeps moving the delivery date back.
JEB[&o]
gcb069 01-22-2006 03:41 PM
I need help my farther inlaw gave me a 1/4 cub (he said B-USA) but i don't know if it a Sig or B-USA its about 20 years old with a ST S90 on it. He made the wing one peace but they bolt on with center. Looks like the wing joint is on the right side of center. if its a Sig i need the point of C/G
Thanks Glenn[>:]
CUB1 01-23-2006 02:45 PM
Glenn,
Sounds like you have a full winged Sig 1/4 scale Cub. The CG is on the main spar....you will be able to fell the the main spar right before the open bays of the wing.
ORIGINAL: gcb069
Thanks Glenn[>:]
Troy540p 01-25-2006 02:18 PM
I'm building the BUSA. the plans and instructions make you think,But all around its a good kit. I've got robart gear going on scale interior and going to cover with WWW.stits.com covering and paint.
Buy the BUSA My 2cents
Good luck
Troy
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
