Fromeco Setup??
I have two Fromeco 2400 Li-Ion and the two matching voltage regulators both going into my RX. My question is, Is this enough or do I need some type of Batt share device, both batteries are on separate switches. Also I am running a 6.0v battery on my DA 50 ignition with no regulator, is this OK? This is all on a 30% Aviation Models YAK 54, all Hitec servos, 2 5945, 2 5625, 1 standard, 1 5955.
Also, how many degrees of deflection do you recommend for ailerons on high and low rates? Thanks, CY |
RE: Fromeco Setup??
You should be fine with the 2400's but the ign. bat? I'm sure if you read the manual or go to their website you will find they work much better on 4.8. I think 6.0 will kill the ign.
RE: Fromeco Setup??
I am not sure about 4.8 vs 6.0, the DA manual says the performance is much better on 6.0v.
Not sure at this point I may just call DA. Thanks, CY |
