Pull-Pull Elevator?
Looking for persuasions regarding pull-pull or push rods for elevator (each half w/78 oz. servo.)
Dynaflite Decathlon / Saito 180. Need to eliminate tailweight. Have already penciled on plans for mods to pull-pull w/ servos moved forward, but can use pushrods. Have used pull-pull RUDDERS on all previous planes. This is my fist "big" plane. |
Pull-Pull Elevator?
I use pull-pull on all the elevators on all five of my big planes. Properly done (pay attention to geometry of layout) I think it is far superior to pushrods.
Pull-Pull Elevator?
i am running a pull pull on my dave patrcick ultimate i sure hope one of those wires never breaks... :D
Ultta hots has pull-pull
My Ultra Hots has pull-pull for both the elevator and rudder. I set up bell cranks to take up the tension of the pull-pull system. Then I used a short push rod from the servo to the bell cranks.
I have run pull-pull systems before directly to the servo arms. I like the bell crank method because I feal it takes some stress off the servos. tonyc |
RE: Pull-Pull Elevator?
Can you post any pics of pull pull in your planes?
| All times are GMT -8. The time now is 06:33 PM. |
