Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
 DA-85 and 35% Aircraft >
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 12-30-2010, 06:43 PM
Default DA-85 and 35% Aircraft
Is anybody flying a 35% aerobatic plane with a DA-85 ? If so, how's the performance, what propeller and exaust system.
Thankyou
Brent
Old 12-30-2010, 06:50 PM
Default RE: DA-85 and 35% Aircraft
I have a 1/3 scale Fokker DVII with a DA 85 and use either the 26x10 Zoar or 27xA Vess prop this is a 42lb. plane and the motor with these props pulls it very well. Hope this helps some what.
Doug
Old 12-30-2010, 07:02 PM
42lbs plane! thats impressive, Id better change my post, I fly aerobatic and was looking for the performance in that catagory.
Thankyou
Old 12-30-2010, 07:10 PM
My Feedback: (32)
bubbagates's Avatar
Brent,
Remember, he is flying a biplane and not a mono-wing and probably flies very scale like
A DA85 on a 42lb aerobatic plane will not be a good match, on a 26lb to 28lb 35% aerobatic plane will be fine, better if you do a pipe
Old 12-30-2010, 11:31 PM
I'd have to say if a DA85 will pull 42 lbs around thats performance but I knew what you were looking for.
Old 12-31-2010, 05:20 AM
Thanks guys,
I fly the 33% Pilot RC Yak right now. I crashed it, but repaired it. I will be looking to replace the plane probably this spring. The 33% is not a readly available plane and was thinking of upgradeing to the 35%
Old 12-31-2010, 07:32 AM
Super08's Avatar
I am flying a OMP/EG Yak 55 at 24lbs. with 102" wingspan. Da85 of a Jtec wraparound and a Xoar 26x10 prop. Great performance with this setup. I just got it finished in time to get it out once before winter hit. I still need to baffle the cowl.
ID:	1540317   Click image for larger version
ID:	1540318   Click image for larger version
ID:	1540319   Click image for larger version
Old 12-31-2010, 04:39 PM
Brent your double posted, read what i wrote you in 3D forum
Old 12-31-2010, 05:26 PM
Ya, I need to delete this thread and keep the 3-D and Aerobatic thread.
Old 01-02-2011, 04:40 PM
My Feedback: (18)
Yes it should be fine I have flown a 35% wild hare extra 300 with a DA85 the planes weight was 27lbs it would do all the manuvers it the book.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
