Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
1/4 scale chipmunk
Old 01-22-2011, 02:09 PM
Default 1/4 scale chipmunk
I have just completed a 1/4 scale chipmunk manufactured by an english company from oxford in the uk .
This has been covered in litho with the rivet detail ,in RAF training colours .
Has anyone any ideas where the CofG should be ,I am working around the main wing spar but at 24 pounds dry weight would like to be sure .
Power from a z 38 with a wooden 20/10 prop 108inch span
any info welcome thanks all
Old 01-22-2011, 02:35 PM
My Feedback: (159)
Default RE: 1/4 scale chipmunk
As for the cg I would contact the manufacturer or the designer listed on the plans.
As for your engine choice in my opinion the plane will be under powered and heavy do to the engine you have chosen.Check out the weight of a DLE 30 or DLE 55 and you will reconsider. You can achieve a much higher engine to power ratio.The plane will have a signicant drop in its overall weight and actually need less power.
Yes I speak from experience.
I hope you find my comments helpful.
Old 01-22-2011, 04:13 PM
I have a 101" Super Chipmunk. It weighs 26lb 11oz. The designer recommended a CG of 28% mac. Mine flys very nicely at 31%. Is very aerobatic in the old style of aero's, even knife edge flight.
The engine is a Z 62. On a 21 x 10 prop it flys ok but the blades go ballistic and very noisy at top revs. It is much better on a 22 x 10.
Hope this helps
C de J
Old 01-23-2011, 06:22 AM
thanks Glen but the manufacturers no longer exist allthough the model is superb
hence the reason for the enquiry
I had thought about another engine but the aircraft was produced before exotic engines like the DLE were available
the engine of choice was the agricultural z38
thanks again Richard
Old 01-23-2011, 09:49 AM
My Feedback: (20)
Richard, plug the numbers for your model into this spread sheet. Use 10% stability margin to start. It has given good results for me.
http://adamone.rchomepage.com/cg_calc.htm
Chuck
Old 01-23-2011, 11:53 AM
Chuck , you are a god , thank you what a fantastic web page .
Just crunching the numbers in, will keep you informed
thanks again
Richard
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
