Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
 Dynaflite PA-18 Super Cub Thrust Line >
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 01-31-2011, 04:26 AM
My Feedback: (53)
Default Dynaflite PA-18 Super Cub Thrust Line
Found a partially built, but not too well, Dynaflite Super Cub. Stripped off old covering and I am now covering with flat finish Dove Gray Monokote. No instructions with the airplane. I know that the CG is located 4 1/8" aft of the leading edge of the wing. I'm going to install a DLE-30 and I have a Fiberglass Specialties Super Cub cowl ready to go.
Would really appreciate if anyone had the measurements/locations of the thrust line for the engine. I could approximate it, but would like to get it as close to spec as possible.
Thanks for your help.
Old 01-31-2011, 11:09 AM
Default RE: Dynaflite PA-18 Super Cub Thrust Line
line it up as close to the horizontal stab as you can
Old 01-31-2011, 01:42 PM
My Feedback: (53)
Thanks. That was going to be my default location if all else failed.
Old 01-31-2011, 04:24 PM
i have that kit still in the box , i guess i could drag it out and look at the plans
Old 01-31-2011, 05:21 PM
My Feedback: (53)
That would be great if you could provide me with some measurements. The actual firewall is about 5 1/2X4 1/4". If you had some measurements from top/bottom and side to side, that would be great.
Wouldn't happen to know of any extra windshields for the Cub, would you? Mine is a little beat up, was glued and torn in two spots.
Old 01-31-2011, 05:45 PM
i will go out to the shop tomorrow afternoon and open the kit and get you some measurements
Old 02-01-2011, 04:21 AM
My Feedback: (53)
Thanks.
Old 02-01-2011, 04:48 PM
i am looking at the plans , it does have some down thrust but no right thrust, the plans show two firewalls one on the engine and then rubber mounted to the one on the plane
the crank centerline is 1 inch down from the top of the firewall
Old 02-01-2011, 05:12 PM
My Feedback: (53)
Sounds good. I'm going to mount a DLE-30 and I'll draw the thrust line 1 inch down from the top of the firewall, probably add 2 degrees of down thrust.
Thanks again for your help.
Old 02-01-2011, 06:04 PM
THE 1 INCH IS DOWN FROM THE TOP OF THE 1/4 PLYWOOD MOUNT and not from the top of the fuselage
Old 02-01-2011, 06:33 PM
My Feedback: (53)
Super. Unfortunatly, it would be impossible to mount the DL-30, on the 1/4" firewall, with the thrust line 1 inch down from the top. The thrust line will end up around 1 1/2 inches from the top. I'll have to do some experimenting to see how close I can get it. Might take a little more down-thrust, with the engine mounted a little below the actual thrust-line.
Old 02-01-2011, 07:09 PM
pm me an i might be able to send some pics
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
