Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
 Almost ready- 1/4 piper cub >
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 03-16-2011, 04:35 PM
pipercub4's Avatar
Default Almost ready- 1/4 piper cub
Ok, so I am almost ready to fly my 100" hanger 9 piper cub 1/4 scale. Any last minute final things or checks that you recommend? I have invested a lot in this plane and want it to fly smoothly. Thanks in advance!
Old 03-16-2011, 05:04 PM
CK1
My Feedback: (60)
CK1's Avatar
Default RE: Almost ready- 1/4 piper cub
It is never a bad idea to have a buddy go over the plane after you have checked it . Charge and test receiver and tx batteries . Perform a range test. Check C.G again . Verifiy proper flight control directions and throws. Run taxi tests and recheck everything again before flying . I usually use the AMA safety check sheet for the maiden flight to help prevent overlooking anything .
Old 03-16-2011, 05:30 PM
ggraham500's Avatar
Piper Cubs need a nice l-o-n-g take-off with a gentle climbout to avoid tip-stall. That was the hardest thing for me to remember, but ultimately my Piper taught me patience, rudder control, and smooth turns. I have somewhere between 300-400 flights now on my old H9 1/4 scale and love to fly it whenever the mood hits me.
Old 03-17-2011, 02:38 AM
Lifer's Avatar
Plus one on graham500's comments.
Old 03-17-2011, 03:54 AM
ORIGINAL: ggraham500
I'll go along with Graham as well......don't horse her off the ground. And, if you have never flown a Cub before, I'd suggest you make your first take off from a nice grass strip rather than pavement (if possible). If she starts to pull off line on the takeoff roll don't be afraid to shut her down and start over. You've got to get used to contolling her with rudder on the ground.
Good luck! You'll love her.
Old 03-17-2011, 10:36 AM
pipercub4's Avatar
Thanks so much guys. I really appreciate the help!
Old 03-17-2011, 01:07 PM
roaddog2's Avatar
All the above, 'good to hear! I've got a DP Super Cub that'll need maiden-ing one o' these days. An' then there's "Lefty", my 7AC as well. I expect 'em both to be roughly the same on TO.
So MUCH t' look fwd to!
RD
Old 03-17-2011, 01:23 PM
Texastbird's Avatar
If you are using metal gear servos be sure there is a little locktite on the screw threads. Letting another experienced modeler check it over is great advise. A couple of months ago one of our better pilots was preparing a new plane. Not trying to be too nosey I casually looked over his shoulder and saw some loose screws on his throttle servo. As he was getting ready to put the hatch on, I motioned toward the servo and asked him if he was going to fly it like that. He'd been looking inside that plane for quite awhile but just couldn't see the forest for the trees.
Old 03-17-2011, 09:53 PM
My Feedback: (29)
got a dp p-18 new in the box with a lot of missing parts, found some parts but hit and miss on the fit, any way can you take a pic of your flaps mine dont look right maybe and top and bottom pic to see if my hinge points are the right depth thanks frank
Old 03-20-2011, 10:51 AM
roaddog2's Avatar
Frank99,
Did you mean that for me? It'll be tomorrow b'fore I can get down to it and shoot it!
RD
Old 03-20-2011, 07:54 PM
My Feedback: (8)
Bring it to.our fly in. www.ozarkflyers.org
Old 03-22-2011, 09:54 AM
roaddog2's Avatar
Frank99,
I blew it shootin'! 'Had a wrong setting goin' on. But aside from that, I couldn't get one down in order t' shoot. It needs my Wife to do that for me an' she's 2 days away. If it's real important to you she can help out Fri.
Sorry!
RD
Old 03-23-2011, 12:49 AM
I really appreciate all of the advice on the maiden of a quarter scale cub as I have a sig quarter scale clipped wing that is almost ready as well. I have a OS 160 twin mounted on the nose of this bird and have read many great things about this engine and am looking forward to hearing her in the air. I have tried to follow the full scale picture pack on Hazel's cub as much as I could and have a question that I hope someone can help with. Where can I purchase a scale prop hub that will fit the os twin. I have a hub on the lock nut, but it sticks too far out and looks odd.
Old 03-23-2011, 09:08 PM
My Feedback: (29)
rd2 took 6 yrs to get the p-18 ,no hurry, if she can help great , installed the ailerons and they are perfect. got to get the servos and switch, horns from tower, and a set of 2 inch stand offs too. thanks frank
oh i will post a pic of mine and yall can tell me if it is right
Old 03-23-2011, 11:53 PM
roaddog2's Avatar
F99,
I'll get Her Majesty to get one down asap when she gets home thur nite. W/luck (an' a taste more attn to th' technology) I'll have a couple to post, if not thur, then fri f'sure.
Cross fingers all...
:O)
RD
Old 03-26-2011, 01:53 PM
My Feedback: (29)
here are some flap pic is over hang right? thanks frank
ID:	1584414   Click image for larger version
ID:	1584415   Click image for larger version
Old 03-26-2011, 02:10 PM
roaddog2's Avatar
Frank99,
'Got m' Wife to get a wing down and shot it. Will attach th' results here and hope they help.
RD
Old 03-26-2011, 02:12 PM
roaddog2's Avatar
Images didn't show up! Stoopid machines!
Old 03-26-2011, 02:18 PM
roaddog2's Avatar
This is gettin' ridiculous! I've up-loaded two ways and STILL can't see a thing! Ne'mind; there they are.
ID:	1584425   Click image for larger version
ID:	1584426   Click image for larger version
ID:	1584427   Click image for larger version
Old 03-26-2011, 02:36 PM
My Feedback: (29)
Rd2 mine is wrong trailing edge is to long did you see my pics
Old 03-27-2011, 02:42 AM
roaddog2's Avatar
Yup! 'Looks thataway aright. Look real close @ mine; TE is hollowed out it seems. I could be wrong on that, but as I remember, th' flap fit right snugly in th' TE. Your way can't possibly hurt anything, tho'. 'Long as th' FUNCTION isn't changed...
RD
Old 03-27-2011, 04:42 AM
CK1
My Feedback: (60)
CK1's Avatar
frank99,
It looks like yuor hinges are not set deep enough in the flap. That would explain the trailing edge protrusioin and the leading edge would be higher and farther away from the wing trailing edge.
The hinges need to be repositioned.
Old 03-27-2011, 06:19 AM
My Feedback: (29)
Ct1 I think u hit the nail , rd2 pins make a small v and mine are higher, I am going to drill deeper and see if that will close the gap tks frank Ps do u work on landing gear See giant scale dp p-18 help pics there too tks
Old 03-27-2011, 12:33 PM
My Feedback: (29)
ck1 superman and wonderwoman just kicked tail, the grimlins are gone , any one have any scrap utral coat and scrap ply more missing parts, will pay cash, but making progress thanks to the rc'ers here thanks a mil frank
ID:	1584945   Click image for larger version
Old 03-27-2011, 12:46 PM
My Feedback: (29)
n86 going to try and make that one, p-18 might be ready,if not is the new hanger 9 arf ok to fly thanks frank
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
