Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
1\3 SE5A build
Old 04-15-2011, 12:12 PM
My Feedback: (20)
Default 1\3 SE5A build
Building a SE5 from Peter Rake 35" electric plans, blown up to 1\3 scale ,,this is not good for your first build..lots of big bird fill in to do ..I have done that and have the T shirt to prove it! Doug smiths B-17 will do as one of the projects I have done.. This is a lumber yard of a project to do..
I have plan for a DLE55 for power.Balsa USA has given good advise on some of the strut making..Got some input from Aeroscale and wire , turnbuckles ,and press tool,etc. B17g is Don smith plans the first vet. was SHO SHO baby.the Doug went with this new paint!I just got the pix of the new look.
I finished this plane back in 98 it has 400+ flights as he indicated,,,,
ID:	1594333   Click image for larger version
Old 04-15-2011, 12:32 PM
My Feedback: (20)
Default RE: 1\3 SE5A build
I have to re size all the pixs but will get more up
Old 04-15-2011, 12:52 PM
My Feedback: (20)
trying to post more pixs
ID:	1594349   Click image for larger version
Old 04-16-2011, 09:36 AM
My Feedback: (9)
Looking good and love the SE5 too. Used to live in Port Orange, back in the '80s.
Cliff
Old 04-16-2011, 11:35 AM
foodstick's Avatar
Its going to be fun watching this, I haven't followed a thread on a 1/3 se5 before. I do have friends that would like one that size....
Old 04-16-2011, 07:05 PM
My Feedback: (20)
I have got the 1\3 scale Balsa US Lewis gun and thought I could open the box and assemble a plastic kit "NOT" Its a wood kit . full of dowels ...Still cool but now I have to do this project too...I did get a Vickers in plastic.. seems like you are forever cutting and making parts..i see that there are 1\3 scale wheels from Williams and dubro..I have got a E mail from a British guy who says to build them .. Under the tail parts is the original plan..Here is some of the early pixs..
ID:	1594870   Click image for larger version
ID:	1594871   Click image for larger version
Old 04-16-2011, 07:27 PM
My Feedback: (20)
Here is some of the goody's from aeroscale, I really like the turnbuckles ,they are tested up too 500lbs and the wire, thimbles and presses and press tool are way cool..
Old 04-30-2011, 12:57 PM
My Feedback: (20)
I'm finely making ground seems take forever to cut the sheet steel to make tangs ..the SE5 should have feet this weekend as a friend says,, its not fun till the landing gear are on then the fun begins,,,some pixs of the gain in building..
ID:	1601481   Click image for larger version
ID:	1601482   Click image for larger version
Old 05-01-2011, 07:17 AM
My Feedback: (20)
Nothing like bending 1/4 in wire or should I say ROD..The torch is the only way to get the stuff to be workable ,,The nicro press tool makes good and strong presses .;. And I rely like using the thimbles to turn the wire and keep wear down. gives a good finish look ,no just a wire bent around a tang.
ID:	1601947   Click image for larger version
Old 05-04-2011, 10:04 AM
My Feedback: (20)
Well been working little at a time the wires and gear now come together and can install servo mounts and control cables. Get the motor mount together finish shaping wings and install small ribs and plank ..I'm going to cheat on tail skid and make it with small wheel integrated in to keep the lines as best as pos. I like to fly my stuff not hang up or just show..so tail wheel it is... the press tool is the best makes the wires way easy.. Main wheels are going to be made ,,,Just have a time trying to make my mind up on what to make the tire out of,,Help is welcome!!Some pix from Sunny FL. its 85 out today..
ID:	1604168   Click image for larger version
ID:	1604169   Click image for larger version
Old 05-04-2011, 10:06 AM
My Feedback: (20)
Forgot to put the ugly builder in too..so here is the pix of that ,me... OH!! added the ailerons to it..right now its at 12.6lbs as seen it the pixs
ID:	1604171   Click image for larger version
Old 05-15-2011, 03:50 PM
My Feedback: (20)
All right! got the flying wires for the wing done,, now to get back to building and shaping ..I have had more than my fill of wires and cuts..the weather is getting real hot here in central FL.. and Have to keep to the evenings to build..of coarse the yard and all other stuff needs to get done.
ID:	1609126   Click image for larger version
Old 05-15-2011, 05:25 PM
Com'in along nice'ly! Is this a straight up enlargment form Peter Rakes electric, no changes? Look's like it will turn out great!
Old 05-15-2011, 07:52 PM
foodstick's Avatar
you are making headway.
the biggest problem now is you will find yourself just walking around it..admiring it from every angle..picturing it in the sky !
Old 05-16-2011, 07:08 AM
My Feedback: (20)
Yes this is a direct blowup of the plans...But all the inner framing and supports are not on plan..it was to be a 36" electric..so its relay lightly built on the plan,,I have had to engineer all inner supports and change over to gas and braising..All the tangs for wires and mounts are of lots of
in put and study of pixs of the SE5 on line..I found many pix sites with very in deft pixs..Of coarse help from Balusa and aero scale .. ,,Its been one of the most difficult to do , and Iv built some real monster builds.. Ikonwest is one tough kitty to do lots of them seem to be make it your way.
I have a spare set of plans if you want to give it a shot! here is a pix of the original plans,,
ID:	1609620   Click image for larger version
Old 05-16-2011, 02:04 PM
My Feedback: (20)
I did find that the airfoil is a little bigger than scale but that's nice ,it will be more scale speed and lift at slower speeds.should be the scale trainer biplane fun flyer ,,will be real Sunday slow fly...I kinda like that ideal! it now weighs 13lbs. I going to do reinforcements and servo mounts .then see
what it weighs then ,,the fuse is kinda narrow and side can muff wont fit, will have to use Pitts muff,.trying to keep light but there's lots to install yet..if it comes in at 29lbs. and under than I did my job..hopeful!!
Old 05-28-2011, 11:15 AM
My Feedback: (20)
well as it gets hot I'm doing more yard work and changing the top on my CJ7 jeep for summer..I worked on the balsausa Lewis gun and in about 3 hrs. I got this far..Not realty a bad kit to do ,well spelled out plan and booklet..I did Use forstner bit and hollow out some of the mag. to get ride of dead
weight..The drill and dermal tip for shaping the handles works way good..the Lewis gun is at 1 1/4 oz. that's complete and unpainted..
ID:	1615891   Click image for larger version
ID:	1615892   Click image for larger version
ID:	1615893   Click image for larger version
ID:	1615894   Click image for larger version
Old 05-28-2011, 11:34 AM
Gadget Biker's Avatar
The gun looks good.  Should be able to load it with 20 or so .22LR rounds.
Old 05-28-2011, 11:35 AM
My Feedback: (20)
Forgot last pix of gun
Old 05-28-2011, 11:43 AM
You need to place a quarter or something in one of the photos so we can see the scale.
Old 05-28-2011, 11:47 AM
My Feedback: (20)
BY request a pix with some scale of 1/3 scale Lewis gun..
Old 05-28-2011, 11:49 AM
20 rounds should do it.
Old 05-28-2011, 11:53 AM
huck1199's Avatar
Beautifull work. The top wing mount must have been a real engineering feat to align. What engine are you thinking of.
Old 05-28-2011, 11:57 AM
My Feedback: (20)
I'm still hoping to stay with a DLE55 I have a new one and Pitts muff to use. the wings all were a very time consuming ordeal . The set up for wings and wires were all not on the plan, had to use full scale pixs and drawings ..
Old 05-28-2011, 12:06 PM
My Feedback: (20)
I have been keeping a running tab on the weight of the plane and servos and running gear and I'm in the 22lbs right now ..bare wood airframe is 16lbs..Need to stay 30 and under or need to step up the engine size..
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
