Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
gear doors
Old 04-23-2011, 09:28 AM
Default gear doors
Hi everyone.
I would like to find out if anyone has ever installed a sequencing valve? I want to add it to my giant scale P47. I have the robart retract system and the large air tank. Will the sequencing valve operate with this tank as well or would I need to add a smaller tank? Thanks everyone. I appreciate your advice.
Old 04-24-2011, 05:20 AM
Default RE: gear doors
It should,but more air will give you more cycles.
Old 04-24-2011, 02:46 PM
Boomerang1's Avatar
I have the Jomar electronic cyling unit, it drives seperate servos to operate 2 air valves in whatever sequence you need.
http://www.emsjomar.com/SearchResult.aspx?CategoryID=6
I use the large air tank in one of my jets, it has loads of capacity. Another option is to use an electronic retract/gear sequencing valve (a fancy air solenoid with timers etc built in), popular with jet flyers & expensive like every other jet accesory.
http://www.airpowernet.com/twe3/index.php?cPath=2
Intairco in Oz sell a lot of air system bits as well.
http://www.intairco.net/default.asp
Regards, John.
Old 04-24-2011, 10:55 PM
Thanks John, that web site you sent is exactly what i've been looking for Tim.</p>
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
