Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
 Sullivan Skylight wheels on Robo Struts >
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 04-23-2011, 02:35 PM
AmishWarlord's Avatar
Default Sullivan Skylight wheels on Robo Struts
Ok I'm using the 4.5" Sullivan skylite wheels with aluminum hubs on a set of Robart 672 offset struts. The Tire not clearing the off set and is rubbing against the side of the strut. I can put spacers on it but it looks like it will need over 1/3" and the axial bolt isn't going all the wall through. Think I can get by with a longer axial bolt and spacers or will I need to go to a thinner tire?
ID:	1598022   Click image for larger version
ID:	1598023   Click image for larger version
Old 04-24-2011, 05:56 AM
Default RE: Sullivan Skylight wheels on Robo Struts
I have this same problem on my B-25. The solution was just what you stated...I have 3 nylon washers and a longer axle. This has worked great for more than 3 years with no problems. I am also using Sullivan wheels.
Old 04-24-2011, 06:00 AM
Thank you tevans55.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
