Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
 Giant Super Aeromaster >
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 05-02-2011, 07:40 AM
DJC
My Feedback: (37)
Default Giant Super Aeromaster
I have a Giant Aeromaster that I bought used, recovered and mounted a Saito 220 in it. Now that I am at the point of balancing it I find that there is a discrepency in the instruction book. It refers to a CG point 2 5/8" back from the leading edge of the top wing at the wing tips and then in another part of the instructions is says the CG is 2 5/8" back but atthe fuse. Since the top wing is swept, there is a big differance in the distance of the two CG points when looking down over the aircraft. If anyone out there has a Giant Aeromaster, please tell me where you have the CG.
Dennis
Old 05-02-2011, 04:44 PM
Default RE: Giant Super Aeromaster
Dennis-
For the Great Planes KIT (not ARF), there is also a discrepancy. The plans show it as 3 1/4" back from the LE of the lower wing at the fuse but the instruction book says 2 7/8" at the same spot. I used 3" and it's fine.
Old 05-03-2011, 04:36 PM
Lnewqban's Avatar
Welcome to the RCU forums, Dennis!
There is an addendum for the ARF's instructions that corrects the CG location:
http://manuals.hobbico.com/gpm/gpma1225-addendum.pdf
"Use a felt-tip pen or 1/8" [3mm]-wide tape to accurately mark the
C.G. on the top of the bottom wing on both sides of the fuselage. The
C.G. is located 2-1/2" [64mm] back from the leading edge of the
bottom wing at the fuselage."
Source:
http://www.greatplanes.com/manuals/discontinued.html
Old 05-04-2011, 08:35 AM
DJC
My Feedback: (37)
<span style="font-family: Arial"><span style="font-size: medium">Thanks a lot for the help. Since the Aero Master is discontinued I never thought the manual would still be available on-line. Until now I was not sure if my planeis a kit or an ARF/ARC. Lookng at the manuals for both I find that mine is the ARF/ARC. So that is the CG referance I will follow.
Again, Thanks for all the help.
Dennis C.</span></span>
Old 05-04-2011, 09:17 AM
Glad you got that resolved. Let us know how you make out.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
