Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
 Electric Retracts; good, bad, or no opinion >
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 05-29-2011, 08:08 PM
kenh3497's Avatar
Default Electric Retracts; good, bad, or no opinion
Like the title says......
Has anybody out there have any experiance with the "e-tracts"? They look to be so much simpler that the air systems and I would think it would save some weight also.
Tell your storry if you have one.
Ken
Old 05-29-2011, 09:29 PM
Default RE: Electric Retracts; good, bad, or no opinion
I have to agree with you on the simplicity issue. Another meaning for "plug and play". I have two sets of the e-Flight retracts and they appear to be well-built. The gear wire is metric and it is held in place by two set screws. The drive mechanism is a jack-screw rather than worm gear. Either of those two methods cannot be back driven. There are up and down locks on the e-Flight gear, so there shouldn't be any problems with the gear retracting because of a hard landing.
bb
Old 05-30-2011, 05:18 AM
My Feedback: (53)
Down and Locked... Excellent!
Chris923
Old 06-02-2011, 06:01 PM
kenh3497's Avatar
I wanting to build a 20% Zlin. It looks like it will be in the 12 to 15 pound range. The 60/120 E-Flights may be a bit on the light side for that aricraft. Any sugestions on a suitable unit?
Ken
Old 06-02-2011, 08:56 PM
BEAR-AvHistory's Avatar
Good as long as you match the retract to the plane weight with a good margin. With a small margin these retracts will support a 10lb plane. Total cost for the Fw190 was $66+ shipping
ID:	1618388   Click image for larger version
Old 06-03-2011, 03:00 AM
CK1
My Feedback: (60)
CK1's Avatar
Down and Locked is the way to go . The retracts can be programmed for a desired operational speed based on the weight of the gear(with tire) and the battery voltage that will be used ,
they can also be programmed for customized gear sequencing. No more air leaks , no more sequencing valves , plug and play .
Old 06-03-2011, 09:15 AM
kenh3497's Avatar
The L&D's look good, but I can see $500 for a pair of retracts. It ain't gunna happen for me. I'll lookatsomething else.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
