Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Cub
Old 06-02-2011, 08:31 AM
My Feedback: (98)
voodoodb's Avatar
Default Cub
Need soem help. I have a 1/4 scale Super Cub that I believe is a N'Kon West brand. Is this right? I can't find anything on the web regarding this company. Perhaps I have it wrong. I'm trying to find out what the CG is. I used a Online Calc using the chord and W/S but have to ad a lot of weight to the tail to get it to balance. I'm using a Fuji 32 gas engine.
Doug
Old 06-02-2011, 08:49 AM
vicarh's Avatar
Default RE: Cub
Sorry to tell that Ikon 'nWst is no longer in business. Hope you can get the info from another modeler with this plane. A place to start is about one third the cord the wing cord or possibly the main spar.
Old 06-02-2011, 10:40 AM
Default RE: Cub
http://www.*********.com/forums/show...-1-4-scale-Cub
I have the Sig 1/4 scale J3. Here is a link to some info and comments on it as well as general CG notes. Good luck. Mine flies great with a G23 on ECDI.
Old 06-02-2011, 11:49 AM
All Day Dan's Avatar
Default RE: Cub
Put the CG 30% of the chord behind the leading edge. Those Fujis are very heavy and it's not surprising that you're stuck with having to add some tail weight. Here's an image of me and my Champ with tail weight. It flies great. Dan.
Old 06-02-2011, 11:54 AM
Texastbird's Avatar
Default RE: Cub
I wouldn't be too surprised if you had to add a little tail weight. The Fuji 32 weighs as much or more than many 50cc class engines. It probably won't bother the Cub any.
Old 06-02-2011, 12:51 PM
My Feedback: (98)
voodoodb's Avatar
Default RE: Cub
Thanks Guys. I have it balanced at 28% which is 4 5/8" back from LE. The main spar is 3.5" from LE. 30% is 5". I have been flying it at the main spar and it flew fine. Hopefully it will fly better at the new CG. Spaceworm your link does not work.
Old 06-03-2011, 03:24 AM
Default RE: Cub
ORIGINAL: voodoodb
Thanks Guys. I have it balanced at 28% which is 4 5/8'' back from LE. The main spar is 3.5'' from LE. 30% is 5''. I have been flying it at the main spar and it flew fine. Hopefully it will fly better at the new CG. Spaceworm your link does not work.
Sorry, try this:
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
