Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
smoke tank set up
Old 06-10-2011, 11:45 AM
Default smoke tank set up
Hey guyz, does it cause an issue to set up a two line system for smoke using a "T" to fill? I don't know if sending smoke oil to the tank will also cause the smoke to push it's way thru the pump and into the muffler during filling. I am currently using a sullivan fueler but I don't like it and want to go to a fuel dot simple method if possible. Any help would be appreciated. Thanks, John
Old 06-10-2011, 03:47 PM
My Feedback: (20)
Default RE: smoke tank set up
I use a TME smoke pump with the setup you describe without any problems.
when the pump is off,it does not let any smoke oil through so it all goes to the tank.
Old 06-11-2011, 01:04 AM
Thanks for the info, that helps a lot. How do you like that TME smoke pump? I'm thinking about trying one.
Old 06-12-2011, 10:30 AM
My Feedback: (20)
It works fine.I run a 6.0v nimh 2000 mah pack with it and use
a Perry remote needle valve adjuster to control the amount of smoke oil to the
muffler.Use a on/off switch on my 9c to turn it on/off and have a mix programmed in to
turn it off below 1/4 throttle.
Old 06-12-2011, 11:47 AM
My Feedback: (15)
gboulton's Avatar
It depends on the pump, but MOST pumps (even the cheap generic windshield washer pumps like I use) will, indeed behave as you describe, and allow you to use a t-fitting for filling just fine.  Best idea is to check it first before installation. <div>
</div><div>
</div>
Old 06-12-2011, 05:54 PM
Thanks guyz, great info.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
