Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Paint Weight
Old 06-16-2011, 05:33 AM
Default Paint Weight
Hey fellows!
I'm just wondering how much weight would paint add to a third Scale Piper Super Cub...?
Old 06-16-2011, 09:27 AM
Chip_Mull's Avatar
Default RE: Paint Weight
It depends on the paint and the painter. If it's a two part paint, whatever you spray on weight wise stays on. I am anxious to see the answers on this thread.
Old 06-16-2011, 09:58 AM
Pelle Gris's Avatar
Does it really matter on a 1:3 scale Cub? :-)
Old 06-16-2011, 03:12 PM
mogman's Avatar
I think the lightest is Stitts Polyfiber from F&M. Solvent based, 75% of what you spray on, evaporates.
Old 06-16-2011, 03:30 PM
Thanks, but,, roughly how much weigh?
Old 06-16-2011, 09:29 PM
mogman's Avatar
I'm not sure. I painted my 1/3 Cub with auto paint, 18 yrs. ago, but I'm sure the Cub never even noticed the weight. The thing has so much wing area. I think Balsa USA said if you want to fly a 1/3 cub in a scale-like manner, throw 10 lbs of weight in it! I think mine on floats is about 33-35 lbs.
I would'nt worry about the weight of the paint.
Old 06-17-2011, 06:46 PM
Rudolph Hart's Avatar
Yuo could always weigh it,the amount you wish to apply.Whether two pack or acrylic you are looking for a minimal coating build to achieve a servicable finish.As has been mentioned you get a lot of solvent evap from acrylics whereas two pack is rarely thinned more than 20%.Ms and hs(medium and high solid) 2 packs rarely need more than two medium wet coats over the top of any substrate coating eg primer filler.
Old 06-17-2011, 06:48 PM
ps most 2 packs hs/ms are about 60% solids,that is after it cures you are left with 60% of the initial product weight,hope this helps
Old 06-24-2011, 07:50 PM
weigh it, paint it, and weigh it again. like has been said, you wont notice a change in performance
Old 06-25-2011, 01:44 AM
Pelle Gris's Avatar
ORIGINAL: mogman
True... A friend of mine flies a 1/3 scale Super Cub, electric, at 44lbs. Looks absolutely perfect in the air.
Old 06-25-2011, 02:27 AM
misterbill's Avatar
Paint it with Latex if you're at all worried. Most of it evaporates while drying. I did on my 1/3 Cub, it's possibly the lightest paint finish I've ever put on an aircraft.
How much extra weight? As everyone says, with a Cub who really cares.
Mike
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
