Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Fat Winged Edge
Old 06-18-2011, 03:00 PM
Rfabbre's Avatar
Default Fat Winged Edge
I picked up a badly "damaged in shipment" ARC Edge and put an 18 1/2" x 82" rectangle (no taper) constant chord wing on it. It's kinda like one of the Blings from a couple years ago. I have a DL50 in it. This is a pic of it getting a GC check on my Vanessa CG machine (which I love) just beffore the maiden flight. <div></div><div>The maiden was uneventful. Plane was very stable with good low speed characterics but it was really too windy a day for a good test. The CG seemd a little forward. It currently set at 30% MAC. Inverted flight required absolutely no forward pressure for level flight-something I was totally unaccustomed to. What does that say about the CG???</div><div></div><div>I was curious if anyone else has tried anything like this-putting a non-tapered wing on any 50cc size fuselage - and what were the results?</div><div></div><div>Thanx in advance for your input.</div>
Old 06-18-2011, 03:02 PM
Rfabbre's Avatar
Default RE: Fat Winged Edge
PIC too large. I'll have to resize it.
Old 06-18-2011, 03:05 PM
Rfabbre's Avatar
Here is the pic.
Old 06-18-2011, 04:14 PM
All Day Dan's Avatar
Rfabbre, Here's an image of a plane I designed for a Brison 3.2, about 50cc. The wing area is 1300 square inches. It has a NACA0019 airfoil. The CG is at the 30% point. You can't beat a constant chord wing for good flight characteristics as you have found out for yourself. I know that the IMAC guys fly around at 35% but that's not for me. With no down presure on the elevators it is telling you that the CG is in the right place. Dan.
Old 06-18-2011, 08:11 PM
Rfabbre's Avatar
Thanx Dan
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
