TMMY Scale Composites 27% (120") Cessna 182 TC Skylane.
#126
I'm now in a dilemma at this point before I glue the Cessna's elevators into the horizontal stabilizers. There are two Robart hinge pins glued into the leading edge of the elevator halves. I anticipate the plane to weigh in at around 45-47 pounds when it's completed and even though it will be flown in a scale-like manner, I'm a bit concerned that two Robart hinges may not be sufficient.
Any suggestions or recommendations to give a fella stuck in a rut like me?
#127
Hello ladies and Gents. I'm in search of a set of 4" main wheels with brakes and a 3.5" wheel for the nose strut. The dimensions of the hole the main axles will insert into should be at least around 7mm with the nose wheel hole being no smaller than 6.5mm. I have a preference for scale so if there are any out there, kindly let me know.
#128
I've bought a lot of items over the years from ZY Hobby (contact and converse with "Zoey"). Very helpful and their products are
first rate. If your axle(s) are 7mm, ask her if they can make them with that size ball bearing inserted. Keep in mind that with your
wheelpants, you won't see much of the wheel/tire anyway.
Here------->https://www.zyhobby.com/collections/rubber-wheel-423
Your elevator hinges.....yes, three would make me a bit more comfortable but I don't think there's a flaw in the design, and I don't see
them fluttering, if you were to solder, say, a brass control horn to each rod then make sure the connecting "rod" to each horn is SOLID
and powered by individual high torque (160 oz in. min. each) high voltage servos. I think that the size of the elevators would most-likely
preclude flutter plus you're not going to be flying the plane at high speeds. If you attach everything solidly, I don't think you'll have any
problems. If you're still concerned about the elevators detaching or fluttering, add a third hinge pin in the middle, now.
Also, it's very cool you have an individual servo powering the Elev. trim tab! Tommy thought of everything!
#129
Response to scale wheels with brakes for Cessna 182
#131
Elevator servos
#132
My plane unfortunately did not come with finished flap wells so that has been added to the list of items in my bucket list.
Presently working on changing the fowler flap attachment to the skin of the underside of the wings.
I worked on fabricating a base in which the nylon piece of the fowler assembly inserts into a slot which will then be glued into the cutouts in the wings as shown in the pictures below.
Left outboard fowler flap assembly
Left inboard fowler flap assembly
Right inboard fowler flap assembly
Right outboard fowler flap assembly
Right flap well. Considering making flap wells for my wings
Right wing with flap attached
Left wing with flap attached.
#133
Thanks all for sharing the information
To be clear for the information we collected recently for intl shipping from Thai to worldwide, the customer can contact your local freight broker and see how they charge. It is not cheap. For sea freight to New Zealand, the sea freight cost for 157" Cessna 185 is over $1000 USD which was charged by the freight broker. The production team and Austars only want to help and get the lower cost for you. if you can find a lower cost, just let us know.
Cheers
Teamaustars
Cheers
Teamaustars
#134
Website - https://tmmy.pantown.com/
Email address for Tommy from April 2021 - "TIRAWIS TERAWANIJ" <[email protected]>
That's all I have for him.
Kim
Kim
#135
Kim
Kim
#136
I have ordered 3.75" wheels with 8mm axle ball bearing on Ebay to use as the mains and I hope to find brakes that can be fitted to work together but so far I am struggling to find a set. My ideal brake setup will be pneumatically operated and not electric. Are there options out there to consider with the wheel hub where the brake will install on the side and measuring 41mm?
#137
Guys,
has anybody got access to the info for external nomenclature and internal placards for the 182T? I'm putting together the bigger TMMY 35% 182T and would like to add these details.
thanks
cheers
Peter
thanks
cheers
Peter
#141
A little off topic, can't help myself....
Saw your screen name - "P210N" and was wondering if you've ever seen anyone hand-prop a
Continental TSIO-520 on a P210? Back in the 1990s, a buddy of mine and I flew somewhere for
breakfast in his P210. Came back out to the plane after breakfast to find that the battery was almost
dead. (I have a PPL license w/instrument rating). I hopped in the left seat and stood on the brakes
while my friend pulled the prop through until the engine fired! Must have taken him 15 to 20 tries before
it came to life! He had worked up quite a sweat too. True story!
#142
I've done it once myself with a 520 on the left side of a Baron sometime around '93. It'll get your attention, that's for sure. I was working the line shack for an FBO a hundred or so years ago. It was the dead of Winter and the owner of the aircraft said he "had to go." So I said something to the effect, "watch this!" After pulling the prop through a few times, he hopped-in, made the mags hot and away he went. He must've tried for ten or fifteen minutes to get that engine running before hand.
PSA, Don't try that at home.
#143
My first one was a '66 Deb w/225hp IO-470K.
Had an IO-520 in my '70 V35B. I loved that airplane! Sold it many, many years ago.
Almost, almost bought a Baron after selling the Bo. But not one with a pair of 285hp 520s. I think the 260s (IO-470N) were a better engine....
