UNIDENTIFIED PLANE HELP
THIS PLANE HAS A 90" WING SPAN .I DON'T KNOW MANUFACTURE OR NAME OF PLANE , IT IS A TAIL DRAGGER ,WITH FOAM CORE 1 PIECE WING AND SHEETED FOAM TURTLE DECK ON FUSE , I DON'T HAVE THE TAIL FEATHERS OR CANOPY FOR PLANE . ANY INFO WOULD BE HELPFULL , WHAT SIZE MOTOR TO USE I WAS THINKING MAYBE US-41 - G-62 . THANKS.
My Feedback: (101)
RE: UNIDENTIFIED PLANE HELP
it is a GShark with a few small mods. thewing fairing is added, the cowl is different and theaddition to the ruddr. The Gshark if I remember is 88" ws. Ifit is the GShark, add another 1 to the top of the vert. stab and rudder and some guys back i the day used to add stall strips inboard on theleading edge o the wing.
TX
If it's an early model G-shark, raise the ailerons for your first flight to avoid tip stalling. If I remember correctly, later model fixed that problem, but the early ones were tip stalling motha's.
