Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Mosquito
Old 02-18-2014, 08:50 AM
rdjohnston
Default Mosquito
I am working on a Brian Taylor Giant Scale Mosquito with twim 4 stroke 90's. I am at the servo installation stage and am wondering if there is single plug method for connecting all the servo wires. I figure I will have atleast 12 pairs of servo wires. It would be nice to be able to connect these thru a single, circular multi-post connector. Has anyone out there one this? If so, any suggestions on brand and procedure.
Thanks in advance
Rich
Old 02-18-2014, 12:45 PM
All Day Dan
All Day Dan's Avatar
Try this. Dan.
http://www.gpdealera.com/cgi-bin/wga...pgm?I=FUTL7668
Old 02-18-2014, 02:36 PM
Zeeb
My Feedback: (41)
Zeeb's Avatar
A Futaba Sbus setup might be a good way to go if you are flying Futaba and have the radio tx to do the job?
Otherwise, perhaps something like this would help to cut down on the number of things you have to plug in on assembly at the field, but I do not know of anyone making a cannon plug for models. I suppose you might pick up some small ones for full scale planes but I promise you that the price tag for anything used on a full scale airplane will scare you to death.
http://www.taildraggerrc.com/20-awg-...wing-harnesss/
Old 02-18-2014, 09:59 PM
Boomerang1
Boomerang1's Avatar
Multiplex multipin connectors are very popular with jet flyers who need high reliability.
http://www.multiplex-rc.de/en/produc...52c61d42eab670
Yes, they handle much higher currents than a servo is likely to drag but the best feature is they are big enough to solder & heatshrink properly without too much trouble. Six pins, you may need three plug/socket pairs.
Remember that, for example, if you are connecting four servos you only need six pins, positive, negative & the four signal wires.
I'm an electrician who works on industrial machinery. Amphenol brand connections are very popular & rugged, lots of pin configs available, may be a bit heavy. This is their standard product line, they have higher mil-spec connectors available:
http://www.amphenol-industrial.com/index.php/97-series
http://www.amphenol-industrial.com/i...cts/connectors
- John.
Old 02-19-2014, 02:09 PM
flytreetimes
You could also try a welding supply shop. Many of the new generation welders use a quick connect round, 9-12 connector to outlying units such as foot controls etc fwiw flytreetimes
Old 02-20-2014, 08:20 AM
dasintex
My Feedback: (10)
dasintex's Avatar
Thanks in advance
Rich
Do you have the ability to make your own servo extensions?
The reason I ask, I make my own Multi Servo Connector Harnesses for the exact reasons as you have described; I use Latching Polarized Multi Servo Connectors (also called Ashlok Connectors), I got the parts from Hansen Hobbies http://www.hansenhobbies.com/product...nlpconnectors/ if you can't make these they come premade from Thunderbolt RC http://www.thunderboltrc.com/index.p...ndex&cPath=153
The only problem with the pre-made ones, depending on the distance to the servo leads, is that you will have to use Servo Extensions between the Servo Lead and the Multi Servo harness, creating 2 additional connections per servo; on mine, I custom make the lengths of the Harnesses to connect directly to the Servo Leads.
Thunderbolt RC also sells the parts to make your own as well http://www.thunderboltrc.com/index.p...ex&cPath=82_83
Doug.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
