Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
The World Models 100cc Stearman
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 02-26-2016, 04:40 PM
dougflys
My Feedback: (27)
I'm just finishing up my World Models PT 17 Stearman with a DLE 111cc twin. I recalculated the CG and came up with eight (8) inches from the leading edge of the top wing. I'm now in the process of balancing the Stearman and it looks like I'm going to have to add about three (3) lbs of weight to the nose. Does that sound about right?
Old 02-26-2016, 06:23 PM
n8622t
My Feedback: (8)
What's wrong with using the cg recommended in the manual??
Old 02-26-2016, 06:24 PM
n8622t
My Feedback: (8)
I would think that if you use the mfg cg you don't have to worry about it tight??
Old 02-27-2016, 06:44 AM
dougflys
My Feedback: (27)
The manual indicated a CG of 8-1/4 inches from the leading edge of the top wing. I was just checking to insure that was the correct figure. It wouldn't be the first time that the manual was incorrect. Anyway, has anyone completed the World Models 30% Stearman and had to add a similar amount of weight to get it to balance.
Old 02-29-2016, 02:33 PM
n8622t
My Feedback: (8)
Editor on RCU actually did a review ..... You should check it out he built it by the manual, if you need one hehehe��
Old 02-29-2016, 02:36 PM
  #31
n8622t
My Feedback: (8)
I've had 3 world models airplanes and the CG was never wrong or inaccurate
hope this helps
Old 02-29-2016, 02:38 PM
  #32
n8622t
My Feedback: (8)
Still working on mine
ID:	2150046   Click image for larger version
Old 02-29-2016, 03:32 PM
  #33
n8622t
My Feedback: (8)
I found this one to model
Old 03-01-2016, 06:11 PM
  #34
dgiokas
n8622t...great timing. I just finished the tail and wings and was about to start extending the firebox out for my Evo 260. Please feel free to provide as many detailed pictures as you can. I can't wait to see where the CG will end up with all that weight replacing the thin plastic dummy radial.
Noticed you wrapped the exhaust ring. Is that to protect the cowl or to build heat for the smoke system?Also what material did you use. I was considering header wrap to help with the smoke system.
Old 03-02-2016, 02:27 PM
  #35
n8622t
My Feedback: (8)
No that's just the plastic film from the original packaging
Old 03-02-2016, 02:37 PM
  #36
n8622t
My Feedback: (8)
Here's the beginning
ID:	2150457   Click image for larger version
ID:	2150458   Click image for larger version
Old 03-02-2016, 02:41 PM
  #37
n8622t
My Feedback: (8)
Firewall extension
ID:	2150460   Click image for larger version
Old 03-02-2016, 02:44 PM
  #38
n8622t
My Feedback: (8)
I pinned it with 5/16" dowel
ID:	2150462   Click image for larger version
Old 03-02-2016, 02:47 PM
  #39
n8622t
My Feedback: (8)
Here's the sheet metal work
ID:	2150464   Click image for larger version
ID:	2150465   Click image for larger version
Old 03-02-2016, 02:50 PM
  #40
n8622t
My Feedback: (8)
Strip rudder
ID:	2150467   Click image for larger version
ID:	2150468   Click image for larger version
Old 03-02-2016, 02:52 PM
  #41
n8622t
My Feedback: (8)
Paint cowl and strut fairings
Old 03-02-2016, 02:53 PM
  #42
n8622t
My Feedback: (8)
Build panels
Old 03-02-2016, 09:47 PM
  #43
dgiokas
Very helpful shots. Thank you.
Can't wait to see where your CG comes in.
BTW, what servos are you using?
  #44
n8622t
My Feedback: (8)
Old 03-02-2016, 09:48 PM
  #45
n8622t
My Feedback: (8)
CG won't change.....
Old 03-02-2016, 09:55 PM
  #46
n8622t
My Feedback: (8)
I've gone with Hitec 7985 on elevators and 7955 on the rudder. I used some Tower Hobbies CS150 digitals on the ailerons cause I had them and know them to be reliable. Regarding the CG, I will stay with the specified CG location in the manual. Hope this helps
Old 03-03-2016, 10:33 AM
  #47
dgiokas
Very helpful. Thank you.
With regards to CG, just wondering if and how much weight may be required to balance at around 8" back. I'm using some fairly heavy servos and batteries well back. Hopefully will not require any nose weight. I'll be doing a quick mock up soon as the extended box is done just to get an idea. A friend who flew it with the CG well forward said that with the extra power, a nose heavy CG is not an issue.
Old 03-03-2016, 11:05 AM
  #48
Lifer
Lifer's Avatar
n8622t,
What happened to your big Gee Bee?
Old 03-03-2016, 01:30 PM
  #49
n8622t
My Feedback: (8)
Rudder setup
ID:	2150685   Click image for larger version
Old 03-03-2016, 01:31 PM
  #50
n8622t
My Feedback: (8)
Hello lifer I sold it to a jet guy in Ok City Oklahoma .....6 flights were all I could live with LOL
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
