what glue to use.
what glue to use.
Hi guy's,
I am building a 1/4 scale tiger moth and have cut out the doors. 1 each side of the cowl. But ran into trouble with gluing the steel brass covered hinge. It will not hole after I thought it was ok. I could just remove the doors day. I did sand the epoxy cowl forst and also the hinge to make sure it would stick I thought.
So any help would be great.
John
John
Hi,
Thanks for your help guy's. I used Epoxy slow cure. But it didn't do the job. Only the dam cowl has all this epoxy on it now that i can remove by sanding. Small screws would not be small enough. The head of the screw would have to be about 1/16" round any big would look out of place. I don't know what JB Weld is. You could let me know.
John
John
Sand both the cowl and the hinge with coarse sandpaper, and clean with alcohol. I would also drill a number of small holes through the hinge so that the epoxy oozes through and provides a better bond. You should also clamp the hinge while drying if possible.
JB Weld is a 2-part epoxy made for bonding metal and is available in most hardware stores (at least in the US).
There are also a number of vendors who sell very small screws (0-80) so you should be able to find them if you look hard enough.
Hi I just done some checking and I can buy it about 30 K's away from my home. Gee it sound great stuff to use hay. JB Weld. Thanks guy's
John
John
My Feedback: (54)
I have bought extremely small canopy screws from BVM and DreamWorks. So small, you need your bi-focals on for sure!! Neither have them on their website, so would take an email or call. Or look at a local model train shop.
http://www.dreamworksrc.com/catalog/
http://www.bvmjets.com/
My Feedback: (19)
Be sure to buy the slow cure JB Weld as it offers much stronger bonds than the fast cure formula. This is stated in their literature. Hysol is another brand that should do the job and is a world wide brand and they have several formulas. One is very similar to JB Weld.
Hi Truckracer,
I didn't know that you could buy the slow cure one. What I have is this. Set time 20-25 minutes and full cure time is 15-24 hours. is this the one??
John
John
Micro blind pop rivets would work as well... these are 5/64" of an inch body / shank dia, with a head dia of 9/64" of an inch.
http://www.hansonrivet.com/micro-blind-rivets.htm
John M,
John M,
Hi Guy's,
I found a product called Fuller 303. It is fuel proof and can be bought in a long tube and so on. It's grey in colour and used very thin will hold very strong. It is a lot easier to used.
John
John
It looks like it is only in Australia. Dam good stuff, very stick and holes very well. But no-good on Plastic as it makes the plastic go real soft. I'm happy the way it worked for me. I will have the 2 doors flying off once in the air.
John
