Skyline Extra 300LP 30CC 73''
ID
What servos are you running on your Extra?
What's your total weight?
Is your CG at 27% mac per the plans?
Do you fly 3D or just aerobatic?
Do you have many flights on the plane and is the airframe holding up to the vibration from the engine?
Anything else to add or that I should look out for?
Thanks again.
Hi,
- Servos : Power HD 8312mg titanium Metal geared High Performance digital Servo 180oz/in.
- Total Weight : 13.5 lbs. (Average is between 12 to 15 lbs)
- CG : 30% from edge
- Prop:18x10 Carbon Fiber
Fly Mode: Aerobatic - Aerobatic and Aerobatic Mode .... ;-)
- Battery : 2 packs 3000 mAh
- Ultimate Battery Backer (2 batteries are connected to this unit)
- Gas tank: RotoFlow 20 ounce
That is my configuration, and I'm very happy a solid Airplane, I'll show you some pictures of my Extra
