Best Aluminum Spinner Polish
The best would be a rouge wheel and dressing for your bench grinder .
Next best would be Eagle One products " Never Dull " aluminum cleaner and polish. Walmart usually has it in the auto section . Works great on trailer fenders too.
Here's my 4 1/2" TruTurn after wet sanding with 220, 400, 600, 800, 1000, 1500, 2000 and finally 2500. Final polish with rouge and cloth wheel on a 6" bench grinder. It takes a while to remove all the tooling marks.
I've used Wenol, Flitz, Neverdull and even light machine compound. I've had the best results by sanding with 600, then 1000, 2000, finishing up with 3000 all used wet. Polish with a felt wheel using white rouge then finishing up with Wenol in the black tube. Makes aluminum look like a mirror.
Bill, Waco Brother #1
