Electrical issue or servo issue ?????
Hey all,
Been a bit since I've gotten on here to ask, but I'm having an issue with either aileron servos or a "y" connector, when powered up the servos SEEM to work fine, but then something wierd happens after a minute or so of working the ailerons, one side just stops and then returns to zero REALLY slowly while the other side continues to work just fine. I decided to try and isolate the problem by reversing the "y" connector, after doing so the opposite side from the first test seemed to slow as well after a minute or so of operation and also has a bounce when it returns to zero.
I'm at a loss here......any ideas??
Thanks in advance
Biker
Thanks in advance
Biker
Thanks for your help :-)
Biker
I had a lot of problems with aileron servos connected with a Y harness. Floppy operation and they would continue to move after I stopped stick movement. To fix it, I dumped the Y harness and plugged each servo into it's own channel on the radio and slaved them together (you have to have a computer radio to do this). The other thing I did was to quit using servo extensions. I de-soldered the servo lead right at the circuit board then soldered on a new lead that was the correct length to go all the way to the receiver. At the receiver end I crimped on the little contact pins and slid them into a sleeve.
End of any servo issues.
carl
carl
