50cc EMB 314 Super Tucano with inline FS 60cc engine
Hi, All:
Austars now come back again developing new scale model plane. The latest one under development is 50cc Super Tucano suitable for 50-70cc engine.
Technical data:
Wingspan: 2238 mm
Fuselage: 2238
Engine:50-80cc (four stroke 50-60cc inline),
Prop: customised 5 blade scale propeller by Biela team
Material: 3 Version
Version A: full composite with electric CNC retracts (3-5 color schemes)
Version A-1: kit without retracts
Version B: full composite with electric CNC retracts (white color for buyer' customization)
Version B-1: kit without retracts
Version C: fiberglass fuselage with balsa wing (we leave modellers to customize your own color scheme, relatively the price is lower)
Version C-1: kit without retracts
Welcome to discuss the project and let us know your thoughts. We keep the update here in the forum.
Cheers
Teamaustars
www.austars-model.com
[email protected] or [email protected]
Photo reference for scale plane is from Airliners Team
Technical data:
Wingspan: 2238 mm
Fuselage: 2238
Material: 3 Version
Cheers
Teamaustars
Hi Didiwatt:
All molds just finished, hopefully the first demo be in the air next month. Google the website and found Phonnix has a similar 60cc Tucuno, powered by wren44. So, the thrust by K45TP should be ok.
will keep you updated
Cheers
Cheers
Update for 50cc Super Tucano
Update for 50cc Super Tucano Demo Plane.
Be tested this week.
Dry weight: less 6kg so far.
Scale cockpit under production.
STD: electric retracts with brake
There are two versions for future production
Pro Version: Full composite for Turbo engine
Std Version: Composite Fuselage, Built up wing covered
Welcome to give comments and color scheme recommended
Thanks for your support!
Red color scheme supplied by our local Australian modeller Damien and Mitch from WA.
