Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Receiver and Carbon Fuselage
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 02-20-2020, 04:59 AM
Lenticuz
Default Receiver and Carbon Fuselage
Hi,
Maybe I am a little overdramatic, but I have some questions regarding the placement
of the reciever in a Carbon fuselage. I have a 1:2,5 sailplane, the whole front of the fuselage is coverd with
carbon fiber material, after some repairs. I have been reading something about that some people take the
antennas from the reciever outside the fuselage? I can see the logic regarding line of sight, but what is the effect when
the carbon comes between the antennas the transmitter in for example a loop or roll?
And the placement.. Is it wise to place the antennas (of coure 90 degrees of each other) UNDER the fuselage ?
Or does anyone have some suggestions The Reciever will probbably be Futaba R6014 HS
Thank you
Old 02-20-2020, 07:18 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
It is best to run your antennas exterior but not up against the side of the fuselage. You want them sticking out. Shown is a picture of my Pike Giant. You will notice the white stub just under the rear edge of the canopy. That is the single antenna of a Hitec Optima 7 channel antenna. The 1" tip of the antenna runs through a plastic tube that is sleeved with heat shrink tube. Hundreds of flights without any issues.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
