Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Ziroli ju87D Stuka engine down thrust.
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 11-23-2020, 05:07 PM
Water or wheels
Default Ziroli ju87D Stuka engine down thrust.
I am building a Ziroli Stuka. Just installed the engine firewall with the proper right thrust. Today I found specks for control throws etc on the Ziroli web site. On there it has the 2 degrees right thrust, which I have. But also it lists 2 degrees down thrust. There is no info on the plans to indicate this. Has anyone put in the 2 degrees down thrust? If not will the plane fly OK without it?
Old 11-23-2020, 05:22 PM
Water or wheels
Default Datum line
I was just doing some more measuring. Also this is my first Ziroli build. So here is a second question. Is the crutch on the Stuka basically the datum line? If so it looks like the down thrust is built in to the front of the firewall supports. Am I in the ballpark?
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
