Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
1/3 Balsa USA Nieuport 17 >
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 09-08-2021, 07:49 AM
My Feedback: (77)
Default 1/3 Balsa USA Nieuport 17
Help !!! My 1/3 Balsa USA Nieuport new built with DLE 160 twin and using the balance point on the plans is requiring an additional 7 and 1/2 pounds. Two sub C 5 cell Nicads are up against the inside firewall. Any suggestions , PLEASE , Thanks Sarge
Old 09-08-2021, 01:56 PM
Outrider6's Avatar
Not knowing all of the particulars, all I can offer is the suggestion to lighten things in the tail, Keep in mind that lightening the tail by roughly 2-1/2 pounds will have the same effect as adding 7-1/2 pounds to the nose. That is assuming that it is 12" from the CG to the nose, and 36" from the CG to the tail. Because of what is called the moment arm or lever arm (engineering term). Plus, lightening the tail by 2-1/2 pounds not only corrects the CG, but also makes your plane 2-1/2 pounds lighter. It is extremely unlikely that you can remove 2-1/2 pounds from the tail, but every ounce you remove from the tail is about 3 ounces that you don't have to add to the nose. And if you have to add weight, then try to make it "functional weight", meaning adding something or using something heavier that gives you some other benefit. Such as a heavier fuel tank or battery that give you longer flight times, or a heavier prop that gives your engine a better "flywheel effect". Try as much as possible to avoid just adding dead weight, which doesn't give any additional benefits.
See if you can use components back there that are lighter than what you have now. See what you can trim back there (extra length on music wire, shorter servo cables, lighter wheels, plastic clevises instead of metal, etc.. Grams add up to ounces when you eliminate enough of them.
For future reference, another thing that helps prevent this problem is to do rough balance checks before covering the plane. See if you are in the ballpark, and make changes while it is easier to do so. I do this with every plane I build, either by scratch or from a kit. Never assume that a plane will come out as designed, in the balance department.
Hopefully, someone familiar with that particular plane has personal experience and can give you some specifics. Until then, I suggest looking at what I mentioned, which will benefit you anyway.
Old 09-09-2021, 01:42 PM
My Feedback: (14)
Sarge,
WWI planes are like that, the answer is add 7 1/2 lbs to the nose, it'll still fly great. I went the "lighten the tail" route on a BUSA Nieuport 28 I built a long time ago and ended up ripping the tail off on a normal WWI maneuver cause it was underbuilt. Add the weight, fly the plane.
Old 09-29-2021, 08:51 PM
That's a very significant amount of weight you need to balance your airplane. I'm surprised it's that far off from what the plans indicate - I'm assuming you have equipped yours in a similar fashion to what was shown?
I'm wanting to build the B-USA third scale Pup. I wonder if anyone has had any trouble with balancing that model. I know the full size WW1 birds have a bit of an ornery weight and balance requirement, along with their short coupled structure. We still love them anyway!
Regardless, I wish you success in getting your airplane balanced and flight ready.
Old 10-01-2021, 05:36 PM
Default Wow
Are balancing on the bottom wing? Or the bottom of the top wing? Just curious
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
