Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
JW Büker Jungmeister build
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 09-23-2022, 01:07 AM
  #201
mitchilito
So all the basic assembly of the aircraft is DONE. I still have a bunch of detail work to do (install seat, instrument panel, some radio gear etc) and then finish sand/prep for cover. I have to hand it to JW: because of the CNC/CAD design, without much trouble the aircraft builds up perfectly rigged in every respect. Fantastic.
I needed my workbench for a different quick project so I had to move the whole aircraft off of it. I couldn't believe how light the whole thing is (minus tail feathers). This aircraft is INCREDIBLY lightly built. It is also a little bit more fragile than I'm used to. It probably won't take a lot of abuse out at the field but then it's meant to fly, not bang around. Here's a pic of it standing on its nose. The picture can't capture how huge it looks in my shop. It FILLS the whole car bay it's standing in.
BIG
tmac48 (09-23-2022)
Old 09-23-2022, 02:17 AM
  #202
sensei
sensei's Avatar
Maybe someplace it’s already been revealed but what are your plans for covering and finishing materials?
Bob
Old 09-23-2022, 04:10 AM
  #203
mitchilito
Bob, I will be using Balsa USA Planetex light Dacron cloth with Stewart Systems Eco Bond/Eco Fill. Final paint will be Klass Koat epoxy paint.
You will be seeing the process VERY soon.
Old 09-23-2022, 04:14 AM
  #204
mitchilito
Had to clear the bench to get my baby ready to go out this weekend
Old 09-23-2022, 05:00 AM
  #205
tmac48
tmac48's Avatar
I miss mine!!
SHANEC (09-25-2022)
Old 09-23-2022, 01:43 PM
  #206
mitchilito
Oh man, that is gorgeous. What manufacturer? Where’d it go?
Old 09-23-2022, 03:17 PM
  #207
tmac48
tmac48's Avatar
Mitch it was a Peter Barth 1/3 scale, unfortunately I got a little too overconfident with it and it was rolled over onto its back in a severe cross wind landing and seeing that I had a second one 3/4 built I decided that it was to go to the scrap heap.
Old 09-24-2022, 01:43 AM
  #208
mitchilito
OUCH! I'm sorry to hear that. Voglesang down the street here in NC (where I picked up my Bücker) sells the Barth Waco and I've been drooling over it bad!
My little Phoenix YMF is a fantastic and fun toy airplane, but it's more "cartoon scale" than actual scale. But it's so easy to transport/assemble/store etc that it's absolutely one of my favorite models ever. Plus it flies GREAT Yes, I really like it.
Old 09-24-2022, 08:38 PM
  #209
tmac48
tmac48's Avatar
Good bit of flying there buddy!
Old 09-25-2022, 12:01 AM
  #210
tmac48
tmac48's Avatar
Racing ahead now!!!
Old 09-25-2022, 01:00 AM
  #211
mitchilito
[QUOTE=tmac48;12745107]Racing ahead now!!!
[/QUOTE
Wow, you are moving right along. Fun times
Old 09-27-2022, 03:05 AM
  #212
mitchilito
Tons of detail work to finish prior to cover. I tend to leave a lot of final finish work undone as I build so I've got to address all that now.
Here, I've pinned the cabanes. The plans show wood screws pinning the brackets in but I couldn't figure out how that could work: if you drilled the proper size hole for a wood screw through the cabane (and thus the aluminum fitting) then when you tried to screw the wood screw in, the fitting would stop the screw immediately. My solution was to drill and tap the holes then use 3mm button head bolts epoxied into place. I really like the way it worked.
On a related note, the wing struts don't get the fittings pinned because they are ALWAYS under compression. Well, using that rationale, the exact same thing applies to the fore and aft cabanes - but NOT the diagonals. So only the diagonals really need pinning. Food for thought.
All heads to the inside of course.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
