Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
1/3 Scale J3 Cub - Engine Recomendation
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 03-07-2007, 10:58 AM
BalsaBob
My Feedback: (24)
Default 1/3 Scale J3 Cub - Engine Recomendation
Looking for engine recomendations for the 1/3 scale J3 Cub ARF (by Modeltech). (I have the kit on order and have not seen the manual yet ...... for recommendations) Thank you. Bob
Old 03-11-2007, 08:21 PM
rc bugman
My Feedback: (30)
Default RE: 1/3 Scale J3 Cub - Engine Recomendation
It all depends on what it weighs. I have three of these planes which I use as research aircraft and they are nice flying planes.
I flew one with a 3w-75 single cylinder with lots of power and we used to fly it up to 2500 ft agl to take atmospheric readings. Takeoff wt = about 50-55 lbs.
A second one had a 3w-85 twin. A little more power but a lot smoother. The 75 single is rated at 7.5 hp and the 85 twin is rated at 7.8 hp.
If you just wanted to putt-putt around the sky cub-like and your weight remained below 40 lbs, I think a G-62 would be the right amount of power. The kit is rated for a 50 cc gas engine but I think you would feel more comfortable with a little more power.
The current versions that I use are equipped with slotted flaps for slower landings and powered with 3w-106s (the same modeltech planes above which have been altered). Takeoff roll at 65+ lbs is about 20 ft with flaps lowered.
Hope this helps
Elson
Old 03-12-2007, 11:55 AM
BalsaBob
My Feedback: (24)
Elson, Thank you very much for the information. Bob
Old 03-21-2007, 06:17 AM
BalsaBob
My Feedback: (24)
Elson, Will the G62 fit inside the cowl ...... without a need to open up/cut one of the sides for the muffler ? Thanks. Bob
Old 03-21-2007, 07:19 PM
rc bugman
My Feedback: (30)
Bob,
I would think so. I usually don't use cowls on my research planes but I think a 1/3 cowl will almost fit over a 100 twin.
Elson
Old 03-26-2007, 07:15 AM
huey-pilot
My Feedback: (17)
My 1/3 scale cub was the Hazel Sig clipped version with a 120 inch wing span. The plane weighed 27 pounds and flew very well with a Kavan 50.
Old 03-27-2007, 02:26 PM
bzyguy01
bzyguy01's Avatar
I'm building a world models 1/3 scale J3 Cub ARF as we speak....I decided to run a Zenoah GT 80 and cut the cowell to expose the top of the 2 cylinders and plugs. Alot of guys are running g62's and they claim that it is plenty of power. These are weighing in at 26-29 lbs fly ready. I wanted alittle more power so when I put it on floats it will have the power to get me out of trouble if need be.
Old 04-05-2007, 09:19 AM
hanko
if your going to fly on floats, there is no such thing as too much power. Im running a D&B 3.7 twin on my Balsa USA (twenty years old I might add). Good combo on floats. I think the Zenoah 80 twin would be ample also. I live in michigan on a lake and would like to have a float fly some day. Anyone in the surronding area, your more than welcome
Henry
ID:	657535   Click image for larger version
Old 04-07-2007, 10:12 AM
wiz310
I ordered a DZY 48 twin gasser for mine....... I sure hope I did the right thing, as you all seem to have a bigger engine than me. Mine is also the modeltech cub.
Old 04-09-2007, 10:10 AM
hanko
Ive seen guys fly 1/3 scale cubs with old quadra 35's. It doesnt take much, so Im sure youll be fine. I wouldnt have gone with the motor I did, but being as I wanted a big horse for floatsl, I went the D&B 3.7 twin. I originally was going to go with a zenoah 80 twin, but couldnt find one when I need it. Their cheap too consindering what i paid for the D&B.
Old 04-09-2007, 08:19 PM
BalsaBob
My Feedback: (24)
Thanks for all the posts/information. I received my G62 today ...... and the wraparound inverted muffler. I am also using the 2 inch prop drive extension. It all fits nicely in the cowl (but I will have to cut a small hole one side to allow the carb to stick out a bit). Bob
Old 05-02-2007, 08:02 PM
tom mathys
im also boilding the balsa usa 1/3 scale cub.thanks for the ideas on the engine.i was going to go with the g62 also.sometime i would like to put it on floats.....so....................that engine should i go with ya think?everone happy with the engines they choosen?
Old 05-02-2007, 08:28 PM
Stickbuilder
Stickbuilder's Avatar
I have seen several fly well with the OS FF320 Pegasus 4 Cylinder engine. It looks good too, and the only holes are for the cylinders, and that looks scale (kinda-sorta)
Bill, AMA 4720
WACO Brotherhood #1
Old 05-03-2007, 12:58 PM
bzyguy01
bzyguy01's Avatar
Just finished fitting my cowell around mt GT80. Looks great with the cylinders exposed on both sides. Can't wait to get it in the air.
Old 05-04-2007, 04:57 PM
sch-d
World Models 1/3 scale Cub, ZDZ80B2 engine, Robart main gear, BTE tailwheel, Smartfly power distribution, regulators and battery share, Skywriter smoke. Link to the construction photos, (Plane named in honor of "Crashburn T. Throttlebottom"). So far 32 flights.
http://www.flyaways.org/photos/2007/planes/wm13cub
Old 07-02-2007, 01:10 AM
bzyguy01
bzyguy01's Avatar
ds1rc....Your Cub looks great! I finally found time to finish mine and I have put 12 flights on it this weekend. Runs Super nice with the extra power to get it out of trouble at the blip of the stik. My Cub will fly KE great and do nice flat spins as well as great hovers! Will fly scale like a champ and will also take off in about 1.5 feet!!! I'm not exadgerating! I will post a video of a hover soon. The Zenoah GT80 is awesome! I had Ralph Cunningham of RC Ignitions convert the engine back to gas and install Electronic Ignition. (My engine was a used Alcohol unlimited racer engine when I purchased it)
ID:	714931   Click image for larger version
ID:	714932   Click image for larger version
ID:	714933   Click image for larger version
ID:	714934   Click image for larger version
ID:	714935   Click image for larger version
Old 07-02-2007, 09:14 AM
sch-d
bzyguy01
You know that inverted stuff makes all of us old guys look bad. You will enjoy many flights with this Cub. The cross trus construction is a lot stronger than it looks. Have fun and fly safe.
Don S.
Old 07-02-2007, 09:48 AM
bzyguy01
bzyguy01's Avatar
Thanks Don....I have a 33% Edge by H9 w/ G62 and it has alot of power with that plane. It will actually hover it at 22-23 lbs. So those of you that are wondering.....I think the G62 will fly the J3 better than scale and still have reserve power to get you out of trouble. I'm going to put floats on mine and still want extra silly power and this is why I chose the larger GT80 engine. I have plenty of vertical performance but not unlimited vertical. It will hover but not pull out ....J3 kinda harriers out if you know what I meen. I do think that the GT80 is one of the best choices for the Silly pilots like myself but way not necessary for the scale pilots.
Old 08-31-2008, 06:25 PM
sfaust
sfaust's Avatar
ORIGINAL: BalsaBob
Bob, or anyone for that matter, do you know where I can get the prop extension for the G62. I am converting a 1/3rd scale cub to use a G62 as the current engine is underpowered. It's obvious that I am going to need to move the engine back about 2" to make it fit in the cowl, so some sort of a prop extension will be required. Also, any recommendations on a muffler. I want something very quiet, and someone recommended a Slimline muffler.
Old 09-01-2008, 11:17 AM
RC Extreme power
My Feedback: (24)
RC Extreme power's Avatar
Email Ralph, He can make anything you need for a G62
[email protected].
Milton
Old 09-05-2008, 05:35 PM
wiz310
well I hve been flying mine quite a bit recently, and it turns out the DZY 48 twin is plenty and some.
Old 09-06-2008, 06:20 PM
sfaust
sfaust's Avatar
Thanks guys. I did find a source for the prop extension, Horizon Hobby, imagine that
The G62 is mounted, slimline muffler installed, linkages, ignition, etc, all rerouted and its ready to be run up tomorrow. If that checks out, its maiden time on Thursday.
Old 09-08-2008, 08:22 PM
airbornrc
My Feedback: (9)
What are you guys with big cubs using for prpellers when you float fly? I have read that you should not use wood props. I have a Stihl 65cc four stroke in mine. I need a recomendation in a 23x8 that is suitable to float fly.
Mark
Old 04-11-2009, 03:56 AM
SON OF PALEFACE
SON OF PALEFACE's Avatar
Whats the Stihl 4 st out of ???
Old 04-11-2009, 06:03 AM
Tony Hallo
Don't about his, but the 65 cc 4 stoke was used for back pack blowers, I considered doing a conversion some time ago. It may be used in other tools.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
