World Models 1/3 Super Cub
#251
I know what you mean. Everytime I take mine out of the trailer I gather a crowd. I'm thinking of building a 40% one next year. Check out AMR RC for thier 42% Cub they will have available. I'm building their Giant Stick and its a excellent kit. Jerry.
#253
My Feedback: (63)
I have a set of 1/3 Scale WM supercub gear for sale. These were made by Carl Swenson - See attached photos. The gear cost $200, I'll sell for $150/shipped
#256
AB, CANADA
ORIGINAL: Mokken
Would a DA-85 fit well in the cowl? How much of the bottom of the cowl would have to be cut out?
#257
My Feedback: (63)
ORIGINAL: zdsh13
Does anyone have pics of a DA85 install, I'm planning on this engine combo for my super cub.
ORIGINAL: Mokken
#258
NC
Hello, I'm wanting to get the 1/3 clipped wing cub. I'll be stacking it in trailer along with another 35% Edge 540, can anyone give me the measurements of how wide the horizontal stabilizer is and how wide is the main landing gear stance is. I saw a few large clipped wing cubs fly at the Joe Nall this year and got the fever for one. Thanks! Henry
#259
My Feedback: (28)
IA
Sweetpea i am clipping my full wing cub and going to put a BME 95 twin up front >Was wondering did you have to split the cowl as far getting the cowl over the cylinders??
#263
My Feedback: (10)
For the 106 I found that I had to split the cowl. But only the front section that slides over the fuse. It only requires 1 extra screw on each side to mount the cowl and lots of flights later its doing fine.
#264
My Feedback: (28)
IA
OK thanks Sweetpee I am hoping to find a super cub cowl from Airborne I know they dont make the super cub any more but hopefully they have a cowl in stock
#265
NC
LEVER02: Thanks for the info...big bird
#266
My Feedback: (10)
I'd think the 55 will be marginal for anything other than real scale flying. I'd say a 65+ would be the way to go. 80-85 is probably perfect. The 106 is overkill but I only fly around at 1/3 to 1/2 throttle unless its an upline or something 3-dish.
#268
SC
ORIGINAL: ricomari
. Not sure which engine yet....55 or 111 dle. My style of flying is slow with powerful uplines. I enjoy flying on the wing then pull into a loop from level flight....or a slow knife edge. No hovering, is the 55DLE enough? Again thanks!
#269
NC
DLE111...POWER: It's better to have it and not need it than need it and not have it.......AVP had it right! Rudder 7955 and the rest of the surfaces 5645...sound good?
#270
My Feedback: (63)
I have all 5645's on mine, I see no reason to have a 7955 of the rudder, unless you have one laying around.
I'm flying this weekend and will bring the HD camera and have someone video mine flying. It's such a joy to fly, and the zrcgf 62cc on the front pulls it around fine. It will hang on the prop at full throttle, then slowly tail slide, lots of fun!!!!
#271
NC
GREAT! I have five 5645 sitting around collecting unemployment. Looking forward to your video. What is your electrical set up....Batt., regulators, switches?
#272
My Feedback: (63)
I'm running dual A123 packs (unregulated) through a smart fly bat-share, to a Fromeco Wolverine switch. Have an a123 pack on a 6v regulator on a JR charge switch, with a smart-fly ignition cut off.
#273
NC
I want to keep it simple also, I have a cube charger for Li-on batt. so I want to stay with li-ons. Just have to put it on paper! What do you charge the 123's on. What are you using for the throttle servo......is the 6vplus okay?
#274
My Feedback: (10)
I did 2 6800 LION packs (they are large and heavy) and 2 2400 packs for ignition and smoke. I use MPI standard regs at 6V including throttle since my 3W106 has a DA ignition. 4 Switches. I also have the Batt share in my plane. I used 8411's on the surfaces and 811 on the throttle.
#275
My Feedback: (63)
6.6v is nominal voltage on A123 packs, around the same for a 6.0v NIMH battery. All of my airplanes have A123 packs, and I use my Fromeco cube to charge them. I have a JR DS821 on the throttle. I have not had any problems with A123 packs with any servo I'm put them on. Have lots of 5645's, 5945's, 5955's and 7555's, even the cheap JR analog servos work.
