top flite BONANZA CG ???
RE: top flite BONANZA CG ???
Most people seem to be adding nose weight to get to the addendum measurement given in the manual. There have been some discussions concerning the V tail incidence being incorrect in the kit which make the plane perform as if tail heavy. I am building the straight tail.
NC
I'll check my CG and get back to you. I'm pretty sure I used the plans cg (no mention of different cg on the addendum list I have) and flies nice.
NC
Did not look in the manual, but after three flights this morning in one of my Bo's I measured the CG. It comes in at exactly 6 1/4" from where the wing fairing meets the fuse. Which would be ~5 5/8" from the bulkhead on the front of the wing where the two dowel rods are located. I like the in-flight performance with this CG. The Bo' I flew today weighs 15.0 lbs. My other weighs almost 16 lbs. Both powered with OS 1.20 Four-Strokes. Whether a low high speed or low slow speed pass, you cannot beat the realistic sound and profile. Full flaps with gear up is awesome down on the deck. A buddy took some video this morning of my third flight. Don't know how to post a video here, but with some advice from those that have I'll be glad to share. What a great stress reliever to fly such a great scale model that Top Flite used to offer. Bring it back so others can join in the fun!!!!
Dave G.
Dave G.
The building notes that came with my kit states:
"The recommended initial balance point is 6-3/8" aft of the leading edge of the wing center section. Some modelers have reported that with larger more powerful engines, such as a .90 2-stroke or 1.20 4-stroke engine, that the model was overly sensitive in pitch. You should initially balance your model at 6" (5-3/4" with retractable landing gear) - even if you are using a smaller engine. Then, adjust the balance aft to obtain the handling characteristics you desire. Also - DO NOT EXCEED THE RECOMMENDED CONTROL THROWS UNTIL YOU HAVE ADJUSTED THE BALANCE. "
I hope this helps you.
could you please tell me the controls set up i just bought a used one thanks allen>> [email protected]
My Feedback: (540)
EMAIL: [email protected]
http://www.top-flite.com/manuals/index.html
http://www.top-flite.com/techsupport/technotes.html
Stock # Mfg. # Name CG Elevator Throw: Aileron Throw: Rudder Throw: Flaps Incidences: Engine Thrust:
High Rate Low Rate High Rate Low Rate High Rate Low Rate Takeoff Landing Wing Stab Right Down
TOPA0305 BON9 Beechcraft Bonanza Gold Edition 6-3/8 11/16 9/16 3/4 1/2 1 3/4 n/a n/a 2 2
manual is on PDF
manual is on PDF
