Building the Hangar 9 Cessna 182 Skylane
#1253
Hi, can you tell me where you got a longer prop lock nut for the Gemini 160. With the onboard starter, freewheel unit and spinner backplate, the locknnut will not reach the crankshaft threads?
#1254
There were two lock nuts supplied with the Gemini if I can recall. One of the was long enough to reach the crankshaft threads. I believe Truturn also sell locknuts. Try them to see if they have a longer one. Good luck and let us know if you find one. Curious to know the size of prop being used.
#1264
You have me drooling over your pics. You panel is awesome, and your doors are just flawless. How much clearance do you have when using the 20 in prop? I imagine you pretty much creasing it in while landing. Do you have pictures of it in flight?
#1266
Mine is still flyin'. It has a stinky ol' OS160 and a 3 blade prop. Lots of prop to ground clearance! Had to rework the nose wheel pant last month though. The darned thing went lean on me and had to deadstick in. That plane is a lot to deadstick on a low flying turn! Seems like that wheel pant is always catching heck! Anyway, ... got it back in tip-top shape. May load it into the trailer tomorrow, just in case the weather warms up a bit this week.
#1269
Mine has a lot in it. I have lights, breaks, electric starter for the OS engine, five batteries up front around the firewall and a scaled cockpit with two pilots. Sure looks scale...
#1270
The Emcee at the Thompsonville Air Show once forgot I was up with mine while they were cleaning up a crash on the runway. I was loitering, for several minutes, on the far end in the backfield waiting for the runway to clear. I sent my spotter to go over and help with the cleanup cause I was getting low on fuel. In the meantime the Emcee started lining up two choppers on the runway for the next part of the show. I was close to running out of fuel so I started to land. The Emcee then caught a glimpse of my 182, out of the corner of his eye, and he started yelling on the Mic, "Oh, my God, there is a full scale plane landing." When I heard that, I started looking for the full--scale plane and and started to waved off. But, ... then I ran out of fuel and had to return to an approach on the runway. Then, I had to dodge the two chopper pilots who were trying to retrieve their choppers off the runway so the full-scale could land. What a mess! I landed long. Then the club President came down to tell me that the Emcee mistook my plane for a full-scale. We then had a discussion about the Emcee needing to get his glasses re-checked, cause he just went to the eye doc a couple days ago. ! Real story!
#1271
FL
hey guys are there anyone still around? i need the cg point on this bird, just acquired one that is totally built and never flown, just got done changing over to spectrum radio and double checking servo set ups ect. but i have no idea where the cg point is. anyone?
