Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Hellcat Build with 250cc Radial
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 01-15-2009, 03:57 PM
flyn2high
flyn2high's Avatar
Default RE: Hellcat Build with 250cc Radial
Thanks Knot. Every shop needs a CNC ha ha. You can do really cool stuff on it. Later I will show you a photo of it.
Here is another view of the dummy engine mount sitting on the rear cowl former.
Old 01-15-2009, 03:58 PM
flyn2high
flyn2high's Avatar
I made up a ¼” ply wood frame to support the next to formers. Remember that weight is not an issue for the plug
ID:	1111480   Click image for larger version
Old 01-15-2009, 04:00 PM
flyn2high
flyn2high's Avatar
Now to add the stringers. As I said I used the side view outline of the 3 view to size the formers. This later proved to be incorrect.
ID:	1111482   Click image for larger version
Old 01-15-2009, 04:01 PM
flyn2high
flyn2high's Avatar
Here I am checking for fit on the fuse. Looks good so far.
ID:	1111484   Click image for larger version
Old 01-15-2009, 04:02 PM
flyn2high
flyn2high's Avatar
Now to sheet it and check it again.
ID:	1111488   Click image for larger version
ID:	1111489   Click image for larger version
Old 01-15-2009, 04:04 PM
  #31
flyn2high
flyn2high's Avatar
By the way I made a nice sanding tool with 60 grit paper attached to a foam packing pad with 3M77 spray adhesive. It does a quick job of sanding the balsa sheeting.
Old 01-15-2009, 04:06 PM
  #32
flyn2high
flyn2high's Avatar
Now on to the leading edge of the cowl. Here I am using scrap balsa blocks. Balsa USA bag of blocks is great for this. I arranged them like a jig saw puzzle until I had enough coverage. Then I glued them in place and attached a second copy of the forward former from the cowl plug base.
ID:	1111492   Click image for larger version
ID:	1111493   Click image for larger version
Old 01-15-2009, 04:08 PM
  #33
flyn2high
flyn2high's Avatar
Now to cut the od on the band saw and the ID on the scroll saw and check for fit
ID:	1111495   Click image for larger version
ID:	1111496   Click image for larger version
Old 01-15-2009, 04:11 PM
  #34
flyn2high
flyn2high's Avatar
After lots of sanding and elbow grease I discovered something wrong. There was not enough room left in the leading edge for the air scoop feature. It turned out that the 3 View was incorrect. I was short by ¾ of an inch on the bottom of the leading edge of the cowl.
Old 01-15-2009, 04:12 PM
  #35
flyn2high
flyn2high's Avatar
Oh well it is easy to fix with body filler and more balsa. The following photos show the extra solid balsa that I added to the leading edge ring and a web guide on the cowl base. I would use this guide to build it up with autobody filler
ID:	1111499   Click image for larger version
ID:	1111500   Click image for larger version
ID:	1111501   Click image for larger version
Old 01-15-2009, 04:19 PM
  #36
flyn2high
flyn2high's Avatar
After filling I checked again on the clearances to the engine. Actually the outline drawing for this engine that are on-line do not take into account that the valve lifters move up and down. This makes it effectively larger. I needed to add more material to my cowl to allow the lifters to clear. I was using a sheet of polyethylene between the front and base of the cowl so the body filler would not fuse the two together when it hardened. In the process you can see that I added a pink foam base with clamping pads. This was so that I could clamp it down and sand with two hands.
ID:	1111509   Click image for larger version
ID:	1111510   Click image for larger version
ID:	1111511   Click image for larger version
ID:	1111512   Click image for larger version
ID:	1111513   Click image for larger version
ID:	1111514   Click image for larger version
ID:	1111515   Click image for larger version
ID:	1111517   Click image for larger version
ID:	1111518   Click image for larger version
Old 01-15-2009, 04:22 PM
  #37
flyn2high
flyn2high's Avatar
Ahh that is about right . . .
Now to shape the leading edge lower scoop I needed to cut away the lower section and then glue it back.
ID:	1111526   Click image for larger version
ID:	1111527   Click image for larger version
Old 01-15-2009, 04:23 PM
  #38
flyn2high
flyn2high's Avatar
More shaping and checking.
ID:	1111530   Click image for larger version
Old 01-15-2009, 04:25 PM
  #39
flyn2high
flyn2high's Avatar
I added the vanes in the air scoop and primed it. I used several coats of laquer based automotive primer surfacer.
ID:	1111532   Click image for larger version
ID:	1111533   Click image for larger version
Old 01-15-2009, 04:26 PM
  #40
flyn2high
flyn2high's Avatar
I added the panel lines and the larger fastener impressions on the surface. Then I used what ever color lacquer that I had handy. I then rubbed it out with compound and it should be ready to build my mold now.
ID:	1111535   Click image for larger version
Old 01-15-2009, 04:46 PM
  #41
flyn2high
flyn2high's Avatar
This was around the end of April and I decided to put the project on hold until my gear came. Jets were becoming popular in my club and after much research on what would be scale but not too difficult to fly I got a Skymaster F-15. Shortly after the jet arrived my gear came but I was committed to the Jet at this point. I don’t want to get too off track here but I included a few photos of the rocket ship. I used Klasskote and did the division of colors with an air brush. The decals were homemade using Decal Pro FX and enlarged and cleaned up 1:32 plastic model decals. First flight nest spring.
On my next post we will fast forward to last month were I focused on the main wing.
ID:	1111548   Click image for larger version
Old 01-16-2009, 02:24 AM
  #42
iiiat
iiiat's Avatar
Beautiful work, and great job catching us up to the present! I'll be watching along and learning!
Tom
Old 01-16-2009, 11:54 AM
  #43
flyn2high
flyn2high's Avatar
Thanks Tom. I am nearly caught up to present day.
I can’t say enough good things about the landing gear. They are incredibly tough. However, due to the large air cylinder and the massive strut diameter the wing can not be built according to the plans. Below is a photo of the gear in place on the side view of the fuselage. When you look at the photo that has the gear retracted it is clear that the wing spar must be moved. It is possible to place it between the rear of the air cylinder and the front of the tire. However, using an aluminum tube to join the center section to the wing tip is not going to fly. There is not enough room for both.
ID:	1112052   Click image for larger version
Old 01-16-2009, 11:58 AM
  #44
flyn2high
flyn2high's Avatar
I recalled reading about a very large Ziroli Skyrader with a 400 cc radial on an RD forum. In this case the spar was also used as the wing joiner. After finding it and reading it over I sent the builder, Phil Clark, an email to get his opinion on my problem. Actually Darrel with Sierra Giant Scale also made his landing gear which is a very similar design to mine. Phil is from the UK but he replied in a few hours with diagrams photos and a lot of encouragement. Thanks Phil!
Attached are some of Phil Clark’s diagrams and photos. You can see the Skyraider here at: http://www.rcuniverse.com/forum/m_6028566/tm.htm
ID:	1112054   Click image for larger version
ID:	1112055   Click image for larger version
Old 01-16-2009, 12:04 PM
  #45
flyn2high
flyn2high's Avatar
My new wing design will have one, in-line spar for the center section and the wing tip. The spar also moves to the rear by 2.26” This is measured from the trailing edge of the original spar to the leading edge of the new spar. This places the spar right in the center of the space between the end of the air cylinder and the tire. I am using a spar that is 5/8” wide x 3/8 thick. This was cut on my band saw from Maple. Poplar is also a good choice as it is very close to the properties of Sitka Spruce for weight and strength. I chose maple because it is stronger and only a little heavier. It also holds screws very well and my local Home Depot has both in stock. Attached is a view cross-section of changes to the wing spar.
Old 01-16-2009, 12:14 PM
  #46
flyn2high
flyn2high's Avatar
To join the wings I am using a 7/16” wide x 1/16” thick type 304 stainless steel strap on the top and bottom of my wing spar. I will have a single long bolt going through joining the wings with a locking nut on the bottom. Attached are the drawings for the straps I made. I use SolidWorks as the drawing program and then use the image to make the part on my little CNC milling machine. If anyone is interested in the 3D version let me know. By the way stainless steel is extremely tough to work with. I suppose plain steel would work nearly as well and you can cut it with hand tools.
ID:	1112066   Click image for larger version
ID:	1112067   Click image for larger version
ID:	1112068   Click image for larger version
Old 01-16-2009, 12:31 PM
  #47
flyn2high
flyn2high's Avatar
The other major change to the wing is where the wing break is located. The plans show the wing break at the dihedral line. If you do this there is only about two inches for the strap on the bottom of the center section. This is because of the notch that is needed for the landing gear strut. I decided to move the wing break out one rib and it gave me a longer spar work with. This is located at rib #7.
Please see the attached photos for the construction of the center section spar.
ID:	1112072   Click image for larger version
ID:	1112073   Click image for larger version
ID:	1112074   Click image for larger version
ID:	1112075   Click image for larger version
Old 01-16-2009, 12:50 PM
  #48
flyn2high
flyn2high's Avatar
What I did is reinforce the spar in the center section and two ribs past the wing joint with 1/8” aircraft ply. The space between the spars is solid aircraft ply going back one rib from the wing joint and also solid where the notch is for the gear strut.
ID:	1112084   Click image for larger version
ID:	1112085   Click image for larger version
Old 01-16-2009, 12:55 PM
  #49
flyn2high
flyn2high's Avatar
I am sure I got a bit carried away with too much strength and weight here. If I needed to build it again I would go with a ½ x 5/16” spar. With the 3/32” aircraft ply on each side it would still be super strong. The key is making it solid between the spars where the strut notch is and at the wing joints. The lightning holes I added are 1 3/8” diameter.
One note is that it is important to align the angle rib #7 at each end of the centersection and the wing tips. This much be perfectly square so that the wing is straight. I used a nice heavy flat plywood board. Mine had Formica on each side. I used some 3M77 adhesive and sprayed a light coat on a sheet of polyethylene. Then I stretched it over one side of the board and took out any wrinkles. Epoxy will not stick to the polyethylene sheet. Before hand I used my belt sander to square up the ends of my center spar. Then I used the flat board to position rib #7 and make sure it was a flat as possible while the epoxy dried.
ID:	1112093   Click image for larger version
ID:	1112094   Click image for larger version
ID:	1112095   Click image for larger version
Old 01-16-2009, 01:30 PM
  #50
flyn2high
flyn2high's Avatar
Now for the wing tips
ID:	1112119   Click image for larger version
ID:	1112120   Click image for larger version
ID:	1112121   Click image for larger version
ID:	1112122   Click image for larger version
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
