Power Setup Help???
I am new to the larger gassers and am in the process of setting up a 88" Wild Hare Edge 540 that I aquired from a fellow club member. I am looking to use a setup similar to what a few guys in my club reccomend so that it will be easier for them to assist me in troubleshooting in the future. Here is what I am looking to use.
Radio - Futaba 7C Engine DLE 55 Servos Hitec digitals (not sure of the model, but what the plane was previously flown with) Batteries - 2 Each, Dual Battery Setup - Fromeco Li Ion http://www.fromeco.org/products/01frc2600-100/ with dual JR Leads Switches - 2 Each already in the plane. Regulator - 2 Each MPI MKIII http://www.troybuiltmodels.com/items/MPIR6VNEW.html BEC/Kill Switch -1 Each http://www.troybuiltmodels.com/items/WRCIBEFV2.html My question are: With Dual leads on the batteries and on the regulators do I need 2 additional switches for the redundancy. How would you wire this setup? Thanks |
RE: Power Setup Help???
I vote to ditch the regs and use a couple of A123s. (WrongWayRC rules !) There are switches available with a Deans in and multiple JR outs. [link=http://www.smart-fly.com/Products/Switch/switch.htm]Smartfly[/link]
Pick some sort of ignition battery eliminator and loose the ignition battery too. |
ORIGINAL: Taildragger726 I vote to ditch the regs and use a couple of A123s. (WrongWayRC rules !) There are switches available with a Deans in and multiple JR outs. [link=http://www.smart-fly.com/Products/Switch/switch.htm]Smartfly[/link] Pick some sort of ignition battery eliminator and loose the ignition battery too. |
An IBE will let you fly on only two packs, would be fine on only one pack but two fulfill the redundancy need.
I know that Richard at [link=http://www.wrongwayrc.com]WrongWayRC[/link] has an ignition power lead that drops the voltage to keep the ignition happy. |
| All times are GMT -8. The time now is 09:13 PM. |
