RCU Forums
-   Giant Scale Aircraft - General (https://www.rcuniverse.com/forum/giant-scale-aircraft-general-467/)
-   -   pull/pull system (https://www.rcuniverse.com/forum/giant-scale-aircraft-general-467/6442798-pull-pull-system.html)
Jon Easley 10-02-2007 10:20 PM
pull/pull system
Hi I am building a balsa nova 120 size and the rudder control is a pull/pull system the instructions are very vage on how to do this I do understand how it works and how to hook it up on the rudder and the servo my qusetion is on the cable??? I am not sure the correct way to connect the cable to the clevis it says to make sure that the cable runs through the brass sleeve three times does any one have picture on this I have never delt with a pull/pull before any help would be great
thx jon
3dd 10-02-2007 10:46 PM
RE: pull/pull system
i use dubro 4/40 threaded solder on conectors and put that on the ends of my cable and solder it real good
