RCU Forums
-   Giant Scale Aircraft - General (https://www.rcuniverse.com/forum/giant-scale-aircraft-general-467/)
-   -   Engine Fire Wall Thrust (https://www.rcuniverse.com/forum/giant-scale-aircraft-general-467/6569230-engine-fire-wall-thrust.html)
Skippykix 11-01-2007 08:00 PM
Please help. I recently purchased a Giant Lanier Stinger ARF (84") and it has no right thrust built into the fire wall. The manual lays out how to put in 2 degrees of right thrust "if your engine requires it". How do you know if your engine requires it? I plane on using my trusty Zenoah G-62 for power. If anyone out there has Built the kit or ARF please let me know what kind of thrust if any at all you used. Thanks.
krayzc-RCU 11-01-2007 08:19 PM
RE: Engine Fire Wall Thrust
even with thrust in the firewall of 2 degress usually more is needed to achieve correct up lines.....
http://www.mini-iac.com/Portals/57ad...20trimming.pdf
Stickbuilder 11-01-2007 09:02 PM
Use the rudder to correct the up lines. You will become a better flyer for it.
Bill, AMA 4720
WACO Brotherhood #1
