RCU Forums
-   Giant Scale Aircraft - General (https://www.rcuniverse.com/forum/giant-scale-aircraft-general-467/)
-   -   Saito Engine Question (https://www.rcuniverse.com/forum/giant-scale-aircraft-general-467/7687419-saito-engine-question.html)
twin3d 07-02-2008 07:07 PM
I have a 13.5 lb Senior Telemaster that is setup to haul r/c sky divers. It currently has an old Saito 120. It will carry one skydiver with relative ease but the plane has the capability to carry 3 2 1/2lb jumpers. I have done it a few times but it is a struggle. I am in the process of trying to decide whether or not to purchase a Saito 150 or the 180. Is the 180 worth the extra 30 dollars in cost over the 150. Please keep in mind I will be hauling upwards of 9 pounds for a total all up weight at take off of about 23 lbs. The Telemaster has a ton of lift and I know either would work I just wanted another opinion. I thought about changing it over to gas but that would require a lot of modifications where the replacement of the 120 with either of these would be just a drop in and go. Thanks in advance.
Mike
BobH 07-02-2008 07:32 PM
RE: Saito Engine Question
Well for sure the 1.8 will do the job.. and .. there's always the throttle stick!
twin3d 07-02-2008 08:59 PM
I fly it around at between quarter and half throttle now with nothing on it, I am wondering if there is that much of a power difference between the 150 to the 180 to pay an extra 30 bucks?
BobH 07-03-2008 10:13 AM
You are talking about extra weight.. If the plane will fly on the 150 with the additional weight.. there's your answer.. is the power difference worth the $30bucks? Depends on what you want or need.. its only $30 bucks.
mobyal 07-05-2008 05:39 PM
I have a 180 NIB and I'll split the difference w/ you. PM me if you're interested.
Al
