AeroWorks New Cessna 195
Aeroworks is showing a Cessna 195 at Toledo. I can't wait to find our more information out on it.
All of their models are Pricey. we will have to keep our fingers crossed. |
RE: AeroWorks New Cessna 195
1 Attachment(s)
I saw this pic and just something about the round cowl and the yellow. The wheel pants look a little square to me. I don't think I've seen a Cessna like this before. Is this the proper shape of the 195?
Here is a couple of links to a 195. The pants were quite boxy looking.
http://www.barronaviation.com/Portal...ures%20011.jpg http://www.oldrhinebeck.org/images/n...t26_2005/4.jpg http://www.geocities.com/CapeCanaver...5/Dcp00588.jpg http://witte-aero.com/Images/SNF2006/cessna195.JPG |
The 195 wheel pants are boxy but Aeroworks seem to be about 25% too deep. Also the original wheel pants have a rolled seam all the way around them.
Thanks for the pics Super08. What about the size? I hear there may be two are three different sizes of the 195 coming out. Hopefully one will be in the 90" - 100" size.
ORIGINAL: drdoom Aeroworks is showing a Cessna 195 at Toledo. I can't wait to find our more information out on it. All of their models are Pricey. we will have to keep our fingers crossed. |
If you ever see one taxi with the cross wind gear you will remember the sight. |
ORIGINAL: Gremlin Castle ORIGINAL: drdoom Aeroworks is showing a Cessna 195 at Toledo. I can't wait to find our more information out on it. All of their models are Pricey. we will have to keep our fingers crossed. |
OT, but I could tell some funny stories learning to land in x-winds back when I was a student pilot. Darn near you know what in my pants. [X(]
I just found out the specs from another thread. Great and I just happen to have a 34cc engine sitting NIB looking for a home....
Specs are as follows: Wing span - 90" Wing area - 1350 sq in. Fuse length - 69.25" (rudder to cowl) Weight - 15 - 17 lbs. Engine - 1.6 - 2.2 glow or 30 - 35cc gas Price - TBA |
ORIGINAL: av8djc ORIGINAL: Gremlin Castle ORIGINAL: drdoom Aeroworks is showing a Cessna 195 at Toledo. I can't wait to find our more information out on it. All of their models are Pricey. we will have to keep our fingers crossed. |
ORIGINAL: Super08 I just found out the specs from another thread. Great and I just happen to have a 34cc engine sitting NIB looking for a home.... Specs are as follows: Wing span - 90" Wing area - 1350 sq in. Fuse length - 69.25" (rudder to cowl) Weight - 15 - 17 lbs. Engine - 1.6 - 2.2 glow or 30 - 35cc gas Price - TBA |
Yes, it's a Quick Build.
I'm currently building a Hostetler 195. For an ARF, I thought this one looked pretty good. There is some deviance from scale, but I expect that. Aero Works seemed interested in any suggestions made, for improvements, as the design is not finalized. |
ORIGINAL: SoCalSal ORIGINAL: av8djc ORIGINAL: Gremlin Castle ORIGINAL: drdoom Aeroworks is showing a Cessna 195 at Toledo. I can't wait to find our more information out on it. All of their models are Pricey. we will have to keep our fingers crossed. What is that? |
http://www.flitemetal.com/ It is fairly easy to use . Once you learn how. It's all in the prep work. Once you get good at it, You can make the Model look better than the real thing.
and It can be painted on for your colors. |
ORIGINAL: drdoom http://www.flitemetal.com/ It is fairly easy to use . Once you learn how. It's all in the prep work. Once you get good at it, You can make the Model look better than the real thing. and It can be painted on for your colors. |
Anyone hear anything on a release date or a price yet??? Haven't seen anything on Aeroworks site.
It is a self adhisive aluminum type covering that you put on over your balsa. It is dead soft and applied in the correct manner will look just like polished aluminum.
Check out this link for more info. http://www.flitemetal.com/ |
Anyone hear anything on a release date or a price yet??? Haven't seen anything on Aeroworks site. |
Here is the Aero-Works Cessna 195. Says it wont be out until Feb 2010. That is still 4 months away and its already been 6 months since Toledo! Boy they really are wetting one's appetite with the delay, It is a nice airplane, check it out : [link]http://www.aero-works.net/store/detail.aspx?ID=396[/link] |
1 Attachment(s)
Taken from their site.... Their is a lot more... Gorgeous Cessna...Too bad they didn't put a scale prop on for the Photo's.
I've been waiting for this plane to hit Aeroworks website. The plane looks really nice and scale like and being a prior owner of an Aeroworks plane I know the quality is there. Unfortunately, with a price tag of $895.95 I'm going to have to pass on this one. Just more than I'm wanting to spend on a plane that size.
The landing gear was mentioned in several above postings and as now the owner of one of these birds, I must report that the supplied landing gear is too soft and bends easily with even good landings! The main weak bend point is at the final bend behind the wheel pants where the factory bend angle tends to open up causing the wheels and pants to take on a toe out look which is damn disappointing for an $895.00 model ARF! Anyone else have this defect? Trying to figure out how to fix by reinforcing with B&B music wire standoffs repair or have a landing gear house build a replacement gear with hard enough aluminum to resist bending?
Flicka5 |
ORIGINAL: flicka5 The landing gear was mentioned in several above postings and as now the owner of one of these birds, I must report that the supplied landing gear is too soft and bends easily with even good landings! The main weak bend point is at the final bend behind the wheel pants where the factory bend angle tends to open up causing the wheels and pants to take on a toe out look which is damn disappointing for an $895.00 model ARF! Anyone else have this defect? Trying to figure out how to fix by reinforcing with B&B music wire standoffs repair or have a landing gear house build a replacement gear with hard enough aluminum to resist bending? Flicka5 |
Can someone enlighten me on what "cross-wind landing gear" might be?
Thanks! |
