RCU Forums
-   Giant Scale Aircraft - General (https://www.rcuniverse.com/forum/giant-scale-aircraft-general-467/)
-   -   Project Help (https://www.rcuniverse.com/forum/giant-scale-aircraft-general-467/9347576-project-help.html)
Shrike117 12-20-2009 11:36 PM
Project Help
Hello there. I'm a new member, and a tinkerer in my spare time. However, I have no real prior experiance in aircrafts, and I had a neat thought recently: I want to set up a push prop powered by a 4-stroke engine on a mini-bike frame. The problem is I don't know how to figure for the thrust I'll need. I've found some formulas, but none that meet my needs. Because the bike won't be leaving the ground, I don't need to worry about lift or other aspects of flight, just thrust. Any advice? P.S. Sorry if there's a more suitable thread for this, I saw this and thought it the most appropriate.
Bass1 12-21-2009 12:19 AM
RE: Project Help
I think I would be inclined to adapt something like this to your mini bike frame http://www.bikemotorkit.com/?gclid=C...Fag65QodPGAWJA. That spinning meat clever (prop) in close proximity to limbs and flesh would be worrisome to me[X(]
spaceworm 12-21-2009 02:26 PM
RE: Project Help
Plus, with the pusher prop behind the rider configuration, it likely would be hard to adequately cool the engine without an additional blower.
Shrike117 12-21-2009 04:08 PM
RE: Project Help
Yeah...but there's going to be a cage around the prop.Also, I'm talking about a mini-bike frame, not bicycle. I don't need help with design, I just need help calculating the amount of force.
spaceworm 12-21-2009 04:55 PM
RE: Project Help
Well then... good luck with that....attitude.
What about engine thrust is not a design characteristic?
But, "where angels fear to tread..."
go to http://www.rcuniverse.com/forum/m_42...tm.htm#4292791
ORIGINAL: Shrike117
Yeah...but there's going to be a cage around the prop. Also, I'm talking about a mini-bike frame, not bicycle. I don't need help with design, I just need help calculating the amount of force.
Shrike117 12-22-2009 10:58 PM
RE: Project Help
Sorry, I misspoke when I said I didn't need help with the design. I meant I know the general setup I want, and I plan to make this fan-powered- and thus more unique. I also should elaborate a bit more: I plan to use a standard 4-stroke 1.5 horse engine, it has it's own cooling fan, as the power plant, and set it up with a pulley system & jack shaft to get more rpms out of the prop.
This whole idea is based on this: www.instructables.com/id/Propeller_Powered_Skateboard_1/
How do you determine the size and pitch of the fan ( I had thought that a 24x12 might work) and horse power of the engine?
If the fan were to be mounted off the back of the frame, how much space should there be between the mini-bike and fan so that the fan isn't starved of air?
Shrike117 01-07-2010 09:54 PM
RE: Project Help
up
Bass1 01-08-2010 01:06 AM
RE: Project Help
Heck, This time of year you might as well build one of these babies! http://www.freepatentsonline.com/3861492.pdf
spaceworm 01-08-2010 12:17 PM
RE: Project Help
1 Attachment(s)
As Yogi said "you could look it up". Look at the link I sent before!
Shrike117 01-10-2010 10:11 PM
RE: Project Help
Thanks guys! Bass1: I think that sounds like a great idea, actually. It's very similar to what I wanted to do and I'll probably set it up with the ability to switch out the skis for wheels. Spaceworm: sorry, I checked the link before but didn't see the chart you were suggesting; that should come in very handy!
