What is best thing for jet engine with jeti transmitter
Hi everyone
I have a jets engine: 1- kingtech 2-jetcat 3-Iqhammer With jeti DS-24 . So the question is : What is the best way to get the ECU telemetry from all this type of engines to jeti ds-24. So i can monitor and see ECU data on my ds-24? I did some search but i found some adapters thats work with some type of engine and i think there is a way to have it work without any adapters . If not what is the best adapters out there ? So can you help me with that? Thanks in advance Sam |
Hi Sam, each engine has different set up for the telemetry. For my ACE120, I connect the telemetry port on my ECU to the ext port on my Jeti Central Box 200. Some engines with older ECU might need to add an adaptor in order to do so. Here is the link to my Engine Info. Hope it helps. https://globaljet.club/collections/j...16392338407498 MIke |
