Glow to Electric Conversions Discuss glow/gas conversion to electric here.
Electric B-17?
Old 02-09-2017, 10:06 AM
  #76
mattnew
Originally Posted by eli5539
What size motors and retracts are you using
Eflite power-19's for the motors, a pair of 1.20 sized 85 degree electric retracts for the mains.
Old 02-10-2017, 07:10 AM
  #77
eli5539
Can't find 19's , when I ran a calculator it showed that I could run park 480's on a (4) 3 cell 2200 should get about 6 minutes flight. Why did you decide to go with the size you are using? Just hoping I did not miss something
Old 02-13-2017, 06:34 AM
  #78
mattnew
my bad, power-15s.
park 480's seem small for a plane that is going to be in the 12-15lb range.
The Royal B-17 was originally designed to run on 4 Veco .19 nitro engines... ( this is where my power-19 thought came from ) ...
E-flite power-15s are meant to be a drop in replacement for a .15 sized engine, so they should be roughly equivalent to the original spec of a .19 sized nitro
Old 02-14-2017, 06:22 AM
  #79
mattnew
Old 02-14-2017, 06:25 AM
  #80
mattnew
radio retracts and engine are in.....control surfaces hinged and painted....need to work on the two turrets and get them installed.. at that point she is flyable! more details may come after....
  #81
mattnew
I ordered new fiberglass engine cowls from fiberglass specialties as well....
Old 02-16-2017, 03:52 PM
  #82
eli5539
Cant wait to hear how she flys. Where did you find 50cal guns that fit. Having a struggle finding any add ons. Also what is your distance between the engine mount rails mine is under 35mm
Old 02-17-2017, 05:39 AM
  #83
mattnew
Tamiya Sherman Tanks: part number 9225067
You can just order the .50 caliber gun in 1/16th scale
I cut the engine mounts off and mounted the motors to the firewall....
Old 02-17-2017, 08:42 AM
  #84
mattnew
we got a name today:
Old 02-17-2017, 09:35 AM
  #85
eli5539
Thank you
Old 02-25-2017, 12:42 AM
  #86
I-fly-any-and-all
We're the old aluminum cowls cut for glow engines? I'd like to buy them for my plane. Cut or not.
Old 02-27-2017, 06:42 AM
  #87
mattnew
They are cut and drilled for mounting ... I'm not really sure what they are worth?
Old 02-27-2017, 03:34 PM
  #88
I-fly-any-and-all
I'll send private message with my email
Old 05-22-2018, 07:32 AM
  #89
balsabuilder13
Learning exercises are not used in the real world of full-size airplanes. After 30 years in storage, your dads beautiful 17 deserves to be out=fitted from the start with the RIGHT STUFF. Do not skimp here. I know this is an old post I am writing to. I can't wait to see how the end turns out. Great job!
Old 02-01-2024, 05:59 PM
  #90
Pcworld
What size tires did end up going with and also retracts gear I’m at this point now I’m having hard finding something to
fit in the Nacelle? My planes it says to use 3 1/2 wheels the kit I’m building is Royal b17F 77 3/4 wingspan
looks the same as what you have.
Thanks John
Old 02-01-2024, 08:42 PM
  #91
I-fly-any-and-all
I've got one 4 built royal b17s, they use 90 degree nose wheel retracts and I'm not sure what size wheels.
join the royal kits group
https://m.facebook.com/groups/170232...ibextid=CTbP7E
Old 02-02-2024, 01:33 PM
  #92
Pcworld
Thanks for getting back to me I’ll do some more research
