Funtana Conversion Battery Question
#101
RE: Funtana Conversion Battery Question
I cought a lot of flack about my set. Just to let you guy's know i have just got this system togther so i am not sure on how it will handle the summer heat. Just have to wait and see. I dont think i will have any problem's though.
A little off topic, I thought i would post a few pic of the system in a sig somthin extra.
DK
DK
#105
ID
Hello, i am new to the big elc, seen and i have a funtana 40
that i called hobby lobby and they set me up with a AXI
4120/18 and 70 opto and 5cell 3700 mah lipo
14x10 e apc . And i have advanced the timing
and not enought power? could someone
help me?? its almost sounds like the wrong set up!
thanks ken I also have two 3 cell lipo packs 4000 mah 11.1 in series 22.2
#106
OH
I too have the Funtana 40 with an AXI 4120/18 motor & APC 14x7 prop. I also use the older 70 OPTO ESC and (2) Thunder Power 3s2p 4200mAh batteries in series. Power is similar to a Saito 80 (plenty) this way. If you use (1) 4200mAh battery the plane will fly fine, but with less power. I am currently waiting for the newer A123 batteries to be more readily available, and then I will switch to them. Hope this helps.........
#107
ID
Thank 's John
I have the same esc, 70 opto with hobby lobby's bec
did you change the timing? on yours?
the stock setting was the single beep mode
i had to change it ,it would cut out on throttle up
and make a chopping sound.H.L told me on the set up they sold me
I would not have to touch the timing.
thanks ken
thanks ken
#108
ID
also, when i got the set up the plane had plenty
of power then about the sixth time i flew it
it started that chopping sound on throttling up?
then i read how to advance the timing
the chopping sound went away
still no power. is there a good meter
that can measure the watt's /volts this is on the 5 cell 18.5 flightpower lipo's
ken
ken
#109
OH
Hi Ken; No, I didn'nt have to touch anything.......I've flown mine for two summers now and look forward to my next project; probably a Yak 54 of some sort. Maybe with an AXI 4131 for power. The battery thing has me somewhat perplexed, but as I mentioned the newer A123's look promising and I still fly 28% gassers.......Regards[8D]
#110
ID
Cool, I love the big gassers! hope to start a 29% this summer and my friend fly the hyperion 53 yak
and she is solid as a rock, handle's like on a rail, well I am thinking i will send my esc back
to H.L and hope they will fix the problem??
thanks for yor help and happy flying!
ken
ken
#112
ID
Hey, John its ken I found out it was my esc !! it was not leting the motor
spool up with the watts it needed I put a watt meter to it and she read
290 watts at full throttle?? so i took the 5cell lipo to my friends
hooked it up and got a 1000 watts at full throttle 60 amps!
so the lipo is fine it's the jetti 70 my motor was fine.
thanks ken
thanks ken
#113
WI
I am putting together funtana 40 with size 60 eflite should have more then enough power problem i have is goiging to use 123 batteries total 7in series 2 parallel going to end up with aprox 8 lb if i cut batteries in 1/2 will cut flying time but save about 1 lb i think with size of wigns mite be ok.any sugestions?
Rick
Rick
#117
ID
It's your mah 3300 would give you a longer run time.
try that set up, and with the batts you have you will feel the power
loss back off the power and set up to land.
ken
ken
