cmp giles 202 1.40
VA
Here is a pic of my latest project. the arf was $169.00 from ak models and is nicely constructed. It is 72" span 970 sq inch wing area. 11.5 lbs auw rtf. power is an axi 5320/28 with a jeti 90, and 10s polyquest xp3700 pack(2 5s1p pcks in series)
2,140 watts on a 19x10e prop. I used bluebird high torque servos and a pull/pull for both rudder and elevator. It flies great(only one flight so far)
Kevin
Kevin
My Feedback: (14)
Kevin
Very nice looking Giles-202. I just ordered this came plane. Can you tell me what size servo's you used? I talk to Alex and I am going to be putting a 42cc w/ei power planet is this plane. Alex said he was not sure what size servo's to used and I was hoping that Hitec 475's would work OK. They have 61oz of torque at 4.8 volts. I hope to use 4 of them on this plane ( 2-elevator, & 2 - ailerons) 1 high torque servo for the rudder and a standard servo for the throttle. What do you think?
I bit your electric Giles-202 flies real nice. Do you have any more pic's or video.
Here is a link to my home page if you would like to take a look see.
www.putfile.com/jstanton
VA
Standard servos will be fine on the elevator and ailerons. I would use a very high torque metal gear servo for the rudder.
sory no video yet, but she is well behaved and easy to fly.
Kevin
Kevin
My Feedback: (14)
Kevin
Thanks for the feed back. It is good news to here I won't have to go out and buy any more servo's. I have an all metal GWS rated at 100oz for the rudder and I'll use Hitec 475's for the ailerons and elevator. I will use a standard servo' Hitec 422 for the throttle.
VA
Jim , if you search on the arf forum there are a couple flyers with this plane and even some video. They are using light weight gas engines mvvs 2.6 ? I think the lighter the better esp on this plane.
These guys have a lot of flights on the giles and know what works .
Kevin
Kevin
